Archived from groups: alt.internet.wireless (More info?)
I have a home network with internet access comprised of Netgear DG834G
wireless ADSL modem/router with a PCMCIA wireless card.
I am trying to extend the range of the network to enable a friend to
access the network but find that once I go over 100 feet I start
losing the signal.
I went into CompUSA and was told to buy a Netgear WGE101 Bridge and
that would solve my problem.... I am not sure of whether it will or
not.
I also found a product by Linksys WRE54G and am not sure whether that
will work with the Netgear equipment I have or not.....
Any suggestions?? or comments....
The range I am looking at is around 150 feet with a couple of concrete
walls in between.
Thanks for all help/suggestions provided
Sponsored Links
"rbeidas" <rbeidas@gawab.com> wrote in message
news:ad7ce4d3.0408220539.2740099b@posting.google.com...
> losing the signal.
> not.
> walls in between.
The WGE101 doesn't look like it can act as a repeater by itself. It does
make claims of greater range, but you'd have to wire your laptop to it.
Ron Bandes, CCNP, CTT+, etc.
Reply to Anonymous
rbeidas,
I'm looking at the same option. However, in reading the info, Linksys
says their WRE54G will not work with any other brand router.
Scott
> losing the signal.
> not.
> walls in between.
Reply to Scott
Most popular wireless gear maxes out at 30mW or thereabouts. Best way
I've found to extend range is with 200mW stuff like this:
http://www.senao.com.tw/english/pr [...] 01_all.asp
Price are comparable and combo of their PCMCIA card and access point
basically doubled my effective range.
> losing the signal.
> not.
> walls in between.
Reply to Anonymous
"Scott" <golden@uslink.net> wrote in message
news:4128E445.E11C58CB@uslink.net...
> rbeidas,
> Scott
> > losing the signal.
> > not.
> > walls in between.
Your concrete walls in between are likely to be "deal killers". Any way you
can get both ends high enough to be above the concrete walls?
If you do try to go through the concrete walls, strongly suggest you use a
directional antenna on both ends. For the far end PC, you could use a
product such as the Hawking wireless G USB adapter with +6dBi directional
antenna. I have used this device with good results. YOu can add a 10 ft
USB extension cable (max 15 feet) to allow placement in a window, up high.
Of course you could use a yagi antenna or even a do-it-yourself tin cantenna
http://members.cox.net/tulsaalston [...] eption.htm
On the AP end, it is desirable to use a directional antenna also. However
that might eliminate your internal wireless signal. So perhaps you could
use a high gain omni antenna, positioned in a window closest to the
receiving PC on the far end.
Take a look at www.fab-corp.com for antennas. I have had good service and
products from these guys.
Bob Alston
bobalston9 AT aol DOT com
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.742 / Virus Database: 495 - Release Date: 8/19/2004
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Extend Wireless range
There are 462 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
