Ok, my primary item up for sale is a PNY 9800GT Energy Efficient Edition video card.
Other items include:
HP d530 SFF desktop- this does not power on, I believe it is a bad power supply. It comes with the P4 2.66 Ghz CPU, a CD-ROM drive, and a 40 GB IDE hard drive. Also included is a windows XP Pro installation key which has been verified to work(but has not been used.)
Dell Dimension E521- Has an AMD 64 bit Processor @ around 2.4 Ghz. This worked last time I tried it, all it needs to become functional is a SATA hard drive and SATA CD/DVD Drive. Everything else is included. This still has the ability to be a fairly strong system and it will accept the latest PCI-e graphics cards. Included is the computer itself, all necessary cables to make internal connections, and a Win XP MCE license key which has not been verified, but, like I said, worked last time it was powered on.
OLD CHEAP COMPUTER PARTS BELOW
AMD 64 bit single core processor with Socket 754 Motherboard. Unknown condition, pulled from a system during an upgrade. Board has all front panel connections, 2SATA ports, and an AGP slot, uses good-ol DDR ram.
RAM:
1 512 MB DDR2-400 laptop RAM 3-3-3-12 timings
1 512MB DDR2-667 laptop ram 5-5-5-12 timings
1 256 MB DDR2-533 Desktop ram 4-4-4-12 timings-- this goes with the Dimension desktop above, but I will sell it seperately.
PCI Cards:
3 soft 56K modems
1 56K modem-full-blown, even has the soundcard connection on the board.
1 ATI analog TV tuner- still works for windows XP, no win7 support. Will receive cable TV signals and has a breakout box(included) for Svideo/Composite video + audio in.
1 Linksys 10/100 Ethernet card
1 Siig Fast Serial/Parallel card-have tested and it works great! PCI-e serial cards are overkill, get this and save!
Hard Drives:
1 Hitachi travelstar 40gb 2.5" IDE laptop drive-pulled from working system
1 Hitachi travelstar 30gb 2.5" IDE laptop drive pulled from working system
misc.
1 Sharp laptop inverter pulled from working Dell inspiron 8200(ask for pictures and codes to see if it matches yours)
1 2-slot SLI bridge- card type, not flexible. This works when you have 1 PCI-e slot, two PCI slots of any type, then another PCI-e slot.
Make offers on anything you like.
RAM:
PCI Cards:
3 soft 56K modems
Hard Drives:
misc.
