p4 mobo with only square 12v aux power connector
  • Motherboards
  • Power Supplies
  • Power
January 23, 2003 6:13:13 AM
I would like to use a liteon atx server power supply which does not have the 2x2 square 12v aux power connector on it for the p4 mobo.
Does anyone have any experience using a readily available $3 patch cable which connects to 12v rectangular 4 pin lead and output 12v 2x2 connector to the aux on p4 mobo?
Any advise on safety or stability problems appreciated
More about : mobo square 12v aux power connector
a c 435 V Motherboard
a b ) Power supply
January 23, 2003 8:45:12 AM
Shouldn't be any problem. One generic power supply I used had one attached to a standard 4 pin lead. Several boards use standard plugs in place of the square connector so customers don't have to change power supplies.
a b V Motherboard
January 23, 2003 11:58:53 PM
12v is 12v, using an adapter, it's still 12v.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
