Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Multiple problems, need help...
Not sure whether to post this in the DVD forum, or here, in graphics. It's kinda both. Even somewhat motherboards. Anyways, here is the problem. If I try to play a DVD, in any player, it freezes after a random amount of time. The entire system locks. Always random points and times of play. Wondering what could be causing this. I use a Radeon 9700 Pro on a Gigabyte GA-8INXP E7205 motherboard. As a side note, in the motherboard BIOS, if I enable the TOP PERFORMANCE option, I can't even complete a 3dMark test. It freezes. Last but not least, whenever I power off the computer, it powers itself right back on. Any clues to any of these problems would be greatly appreciated. Thanks.
Tech Support: "Hello, tech support, may I help you?"
Customer: (in a thick Russian accent) "Yes. Monitor is working fine but has sparks and smoke flying out back. Is ok?"
Sponsored Links
There are 981 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
