Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Ga8ihxp and mx300 soundcard woes, please help!
Forum Motherboards & Memory : General Motherboard - Ga8ihxp and mx300 soundcard woes, please help!
Hi all, i just upgraded and my new motherboard (ga-8ihxp) and mx300 soundcard don't get along. When i install my soundcard's drivers i am informed during the installation process that my mx300 is not installed into the primary pci bus and that certain functions may not work correctly and sure enough they don't. When i launch a game sometimes the game hangs immediately or further into it. The m/b has an onboard audio device that i disabled and i have installed the mx300 in different pci slots and have assigned it a unique irq but to no avail. I can remove the card and use the onboard audio which sounds way worse than the mx300 but then again it works..... There is another issue that i think may be related and even the cause of my soundcards problem.....i just don't know enough to be sure.... win98se finds something it calls a pci universal serial bus.... and it keeps finding it even if i delete it in device manager... i have no idea what this could be or what drivers it needs but it may be the cause of the o/s (or whatever)thinking that the mx300 is not installed in the primary pci bus. I have all the latest drivers installed.... everything worked fine and for a long time on my old system, the m/b is as far as i can tell the latest hardware version...3.0... and the bios is up to date.... i installed the chipset drivers and the intel application accelerator.. everything went smooth until the soundcard. Anyone have any ideas? Thanks!
Sponsored Links
You need the patched driver. If you have an FTP for me to send a large file, I can send it. Otherwise, I can give you directions to patch it yourself.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
Reply to Crashman
Hi Crashman, thanks for replying! I was hoping someone could help me out unfortunately i have a slow speed dial up internet connection (26.4k) but if you could walk me through how to patch this i would be forever in your debt! I also use getright so if i had to d/l anything large i probably could do it, just would take a while. I still can't figure out what that pci universal serial bus is that the o/s keeps finding. Once again, thanks for the help!
Reply to davehaze
There are 764 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
