Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Power Supply and Motherboard compatability.
I am going to get a case with a power supply and wanted to know if the power supply supports standard ATX Motherboards but only names the P4 will it still work with a motherboard that uses an AMD processor. I also needed to know if a case says it fits standard ATX, Xeon, Pentium 4 Motherboards will AMD based ATX Motherboards also fit. Thanks for any help :-)
Sponsored Links
yes to both questions.
<i>It's always the one thing you never suspected.</i>
Reply to jlanka
Started like 98 most motherboard use this standard power connector to the power supply. Also make sure you have a good power supply atleast 350watt because most new video cards require 300watt power supply or better.
And if the cases is new and the motherboard is new most likely they will pair together amd or p4 or not.
:smile: "I put a flowmaster on my Nvidia FX VIDEO CARD and reached a db score of 240db on Futuremark's DEAF METER 2003"
Reply to flowmaster
It comes with a 430 watt power supply. case + ps = $149.
Reply to RBco2002
AMD recommeds that the PS have a Max Continous rating on the various rails as follows:
3.3V should be at least 28A
5V should be at least 30A
12V should be at least 15A
Once you're satisified that it meets those requirements, question the quality of construction and noise level next.
If you want more info, a good read can be found at:
<A HREF="http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26003.pdf" target="_new">http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26003.pdf</A>
---There may be more than one way to do it, but why would anyone want to remove the fur from a feline?---
Reply to tuesday630
There are 1007 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
