News
Gearing up for the DARPA Grand Challenge
Today 43 autonomous vehicle teams entered the qualifying round of the DARPA Grand Challenge. In the next tension filled week, the driverless vehicles must steer though a 2.2 mile course at the Fontana Speedway filled with speed bumps, parked cars and tank traps. Read more
Latest Reviews & Articles
Hard Drives, Yesterday And Today: From 500 GB To 1.5 TB
Hard drive capacities have increased in large increments over the last few years, while trends indicate reduced spindle speeds of 5,400 RPM instead of 7,200. We looked at three generations of Samsung hard drives to analyze the performance ramifications. Read more
Best Graphics Cards For The Money: June '09
This month, ATI's new Radeon HD 4770 is missing in action, since online stores are not only unable to keep it in stock, but also de-listing it completely. With violent movements in pricing, though, it'd have been taken off the recommended list anyway. Read more
Editor's Corner: Nvidia’s Ion Revisited, 7.1 Ch. LPCM Fixed
Nvidia's Ion for the do-it-yourselfer launched last month in the form of Zotac's mini-ITX motherboard. Though sexy in principle, the platform had some teething pains right out of the gate. Chris Angelini revisits those issues and uses Ion as a real HTPC. Read more
Core i7 Memory Scaling: From DDR3-800 to DDR3-1600
Do you want a quick Core i7 system, but don’t feel confident sticking to Intel's spec and using the DDR3-1066 memory supported by the processor? We benchmark the most relevant memory speed and timing combinations to check the benefit of going faster. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Games General > PC Gaming > enemy territory -"vsay" followed by "say"- read this post
"How to combind "vsay and say"
Enemy Territory
DANGER!!! DANGER!!! DANGER!!!
Server Admin my consider it spamming!!!
Don't over do it or this will happen to you!!!
It will cause the server spam control to mute you!
It will cause you to get KICKED by admin for spamming!
It will cause you to get BAND from server by admin for apamming!
Some or all of the above will happen to you if go overboard with this information!!!
You have been warned!!!!
Now that I got that out of the way,lets get started:
It's time to show you how to have some fun with enemy territory!!!
Note: Some servers will only allow one"vsay" or "say"at a time.
So make a test script and check the servers you play on.
I've only encounterd one server that I play on that is set up that way all the others execute the hole script,no problem at all.
Did you ever try to"vsay"LetsGo" "vsay"Follow me"but E.T. would only execute the first" vsay" but no go on the second" vsay".
Or maybe you tryed to "vsay"team_FTGoUndercover" "say" blow the entrence,I'll be right behind you!!! E.T only executed just the" vsay" but not the "say".
There are two ways to make enemy territory accomplish the above "vsay"and" vsay"or" vsay" and "say" with no problem at all.
Lets say you wanted to"vsay"CommandDeclined"and then "say"Are you nuts,I'll get killed,death is not an Option!!!
Or maybe you want to "vsay_team"FTExploreArea"and then"vsay_team FTDisarmLandmines"
The best way to do this is with a script:
First you will have to make a script,the trick to make it work is the wait period on the script,you have to set the wait period anywhere from 100 to 300 depending on the speed of your computer.
Here are the scprits for this exeamples:
//Command Declined--Script
set command_1"vsayCommandDeclined; wait 125; vstr comm_2"
set comm_2"say Are you nuts,I'll get killed,death is not an Option!!!"
bind x "vstr command_1"
//Explore The Area--Script
set ftexpl_1"vsay_team FTExploreArea; wait 125; vstr ftex_2"
set ftexs_2"vsay_team FTDisarmLandmines"
bind x "vstr ftexpl_1"
Note:With a script the sky is the limit as to what you can do with it,that is why you can get in trouble with the server admin.
Something like this:
set medic_1"vsay_team Medic; wait 150; vsay_team FTExploreTheArea; wait 150; vsay_team Healme; wait 150; vstr med_2"
set med_2"say ^3That was pertty ^6Cool,^1Huh!; wait 150; vsay Cheer"
This is a good example that will get you in deep trouble with the server Admin,So use some common sence!!!
keep it to one"vsay" and one "say" or one "vsay" followed by another "vsay" making your scripts like this should keep you out of trouble,it all depends on the servers you play on.
A---Remember adjust the wait period,if your computer is average or on the slow side use ait 100, if you computer is fast or real fast than use wait 300,fine tune it to any value between 100 to 300.
B---Make sure there is a space after the semi-colin.
C---Make sure the Quotations are in the correct place.
D---Check your spelling.
E---Don't forget to add some color to your "say"The Witty lines you came up with.
F---The script will execute the "say"and then "vsay"if you choose to set it up that way.
If you going to make a bunch of scripts use the first few letters of the vsay with underscore and a number,works very well,omits duplication of vstr commands.
Here are some vsays for you,just copy and paste to you script,you can use "vsay" or"vsay_team"on this section:
Example:"vsay PathCleared"
Example:"vsay_team PathCleared"
PathCleared
EnemyWeak
AllClear
Incoming
FireInTheHole
OnDefense
OnOffense
TakingFire
MinesCleared
EnemyDisguised
Medic
NeedAmmo
NeedBackup
NeedEngineer
CoverMe
HoldFire
WhereTo
NeedOps
FollowMe
LetsGo
Move
ClearPath
DefendObjective
DisarmDynamite
ClearMines
ReinforceOffense
ReinforceDefense
Affirmative
Negative
Thanks
Welcome
Sorry
Oops
Affirmative
Negative
EnemyWeak
Hi
Bye
GreatShot
Cheer
Thanks
Welco
Oops
Sorry
HoldFire
GoodGame
IamSoldier
IamMedic
IamEngineer
IamFieldOps
IamCovertOpps
CommandAcknowledged
CommandDeclined
CommandCompleted
DestroyPrimary
DestroySecondary
DestroyConstruction
ConstructionCommencing
RepairVehicle
DestroyVehicle
EscortVehicle
Only add "vsay_team with a space to the vsays below"
Example:"vsay_team FTCoverMe"
FTCoverMe
FTDisarmDynamite
FTFallBack
FTCoveringFire
FTMortar
FTHealSquad
FTHealMe (will show a medic icon over head)
FTReviveTeamMate
FTReviveMe (will show a medic icon over head)
FTDestroyObjective
FTRepairObjective
FTConstructObjective
FTDeployLandmines
FTDisarmLandmines
FTCallAirStrike
FTCallArtillery
FTResupplySquad
FTResupplyMe (will show a ammo icon over head)
FTExploreArea
FTCheckLandMines
FTSatchelObjective (same file as FTDestroyObjective)
FTInfiltrate
FTGoUndercover
FTProvideSniperCover
If your out of keys to bind,download ctrl + script from here: http://www.flame-guards.com/module [...] Script_Bin
If you run into a problem executing a script or just to say the information was helpful to you,email me at:
chista154@yahoo.com
I't took me a while to make the script work,my computer is pretty quick and the wait time was causing the script not execute properly,had to go up to wait 300,after I got the wait period set properly eveything started running like a swiss watch.
I've been trying to find some information on this particuliar subject but did not find anything about combinding "vsay" and "say" on Enemy Territory,if someone else came up with the same script I made,I am not trying to take credit for it,The reason I made it is because there was nothing on this perticular subject at least to my knowledge.Just thought I'd mention that.I made my script on 8-20-08,as old as the game is I'm sure someone came up with something similar to this before it did.
I just thought I'd share this information with the gamers of Enemy Territory because a lot of you guys and gals have shared and helped me with a bunch of stuff,as you know enemy territory is not the easyest game to work with,so here is a bit of payback.
Oh,I almost forgot I did say two ways,here is the other way:
Example: bind x "vsay_team IamMedic; wait 150; say I'm on my way to your location!"
Sorry for not using this example "first" and the"script" second!!! ---well this is the other way to do it!!! !
Well,to be Honest,I realy don't feel that bad about telling you about the script first and the bind second ---Just couldn't help myself !!! :lol: :lol: :lol:
Have a great day!!!
Have some fun making scripts or binds remember don't get in trouble!!!
Message edited by Raner on 09-04-2008 at 12:55:11 AM
There are 513 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
