Tom's Hardware > Forum > Applications > Multimedia > AVI frame rate problem
Forum Applications : Multimedia - AVI frame rate problem
i have made 3 clips i want to join together. the 1st and 3rd are long clips and are 29.970. the 2nd is about 10 seconds and is 29.971 so virtualdub cant join them. i tried to alter the frame rate in vdub but it still comes out as .971 instead of .970. i have tried other proggies as well, but can't get the video to be 29.970
the weird thing is, is that vdub says that the frame rate is 29.970 under video/framerate, but properties of the avi says 29.971. why cant vdub add them together if it detects the clip is the same frame rate as the other two clips?
Sponsored Links
Try converting all 3 into a completely new framerate like say 24 and joining the new files together.
Reply to lakedude
you can try VidCrop Pro
Reply to dasli
There are 1360 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
