Tom's Hardware > Forum > Games General > PC Gaming > Crysis & Dark Messiah cause system to lock up on load.
Forum Games General : PC Gaming - Crysis & Dark Messiah cause system to lock up on load.
Hi thanks for taking your time to read this post. First a little background on what is going on, i've played both games before on this computer, i've finished crysis already. But yesterday when i went to load either of these games the system freeze's before anything loads right when the cursor turns into an hour glass. The computer does not respond to ctrl-alt-delete, alt-f4, alt-enter, esc, or anything else i could think of. This is running either crysis.exe from bin32 or crysis.exe from bin64, when i load crysis64.exe from bin64 i get a black screen that i can alt-ctrl-delete out of with an appcrash on crysis64.exe fault from crysystem.dll. I have the same system lock-up/system freeze issue with Dark Messiah of Might and Magic. I have scanned the internet for 6 or so hours for a solution to either issue i am having. I previously got 64-bit crysis running by disabling nvidias network manager. Oh and here is the tricky part, Enemy Territory : Quake Wars runs just perfect, as if Crysis & DMoM&M dont have a problem. Now here's a list of a few things i have done in between my first play of Crysis and my recent problems.
1. Uninstalled all games on my computer
2. I cleaned the registry using easycleaner then defragmented all drives using perfect disk 2.0 (this also was a defrag of the MFT to move it to the outer edge of the hard-drive.
3. I partitioned my drives into 3 partitions the first for Vista/Pagefile/System files. the second for games and apps and the third for music/misc documents/ect...
4. I Reinstalled Steam, Quake Wars, Crysis & DMoM&M. Applied all patches to Crysis & Quake Wars. Updated DMoM&M through steam, validated all game files then defragmented DMoM&M.
5. I defragmented each individual drive once again
6. I Used Cpu-z to discover my memory was not running as dual-channel but as single channel so i switched the corresponding memory into the corresponding memory slots.
7. I discovered the cpu fan in the computer was not pointing in the right direction so i fixed that issue.
8. Crysis & DMoM&M froze the system (nothing responded) Quake Wars played fine.
9. Repeated steps 1,2,4,5 and #8 occured again
10. Same issues as #8
11. Completely removed Nvidia and all its components and booted in safe mode to install Drivers 175.19
12. Same issue as #8
13. Completely removed Nvidia and all its components and reinstalled beta drivers 175.74
14. Same issue as #8
Nothing is overclocked everything is stock, here is a list of my specs.
- Intel Core 2 Quad Q6600 Processor HH80562PH0568M - 2.40GHz, 8MB Cache, 1066MHz FSB, Kentsfield, Quad-Core, OEM, Socket 775, Processor
- PowerUp GEN-6803 800-Watt Power Supply - SLI-Ready, Dual 80mm Fan (Blue)
- Corsair Dual Channel TWINX 2048MB PC6400 DDR2 800MHz E.P.P. Memory (2 x 1024)
- MEM 2Gx2|OCZ OCZ Reaper
- XFX GeForce 8800 GT Video Card - Alpha Dog Edition, 512MB DDR3, PCI Express 2.0, SLI Ready, (Dual Link) Dual DVI, HDTV, Variable Fan Speed
- Masscool 8WA741 / Socket 775 / Copper Core/Heatpipes / CPU Cooling Fan
- Seagate 250GB Serial ATA w/NCQ 7200/8MB/SATA-3G
- EVGA nForce 750i SLI Socket 775 Motherboard
I thought i would give you all a try before i reformat my hard drive today. I have gotten alot of answers off this forum before, again thanks for your time.
Oh and another thing, i can run prime95 mem+cpu tests with my core temp staying stable so as far as i understand its not the cpu or mem overheating, i've never had issues with the graphic card overheating before.
Ill post my Dxdiag and Cpu-z report just to be safe.
Sponsored Links
DXDIAG
System Information
Time of this report: 9/25/2008, 12:51:51
Machine name: UNICOMP-PC
Operating System: Windows Vista™ Home Premium (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.080425-1930)
Language: English (Regional Setting: English)
System Manufacturer: EVGA__
System Model: nForce 750i SLI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 6142MB RAM
Page File: 998MB used, 14167MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6001.18000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GT
Manufacturer: NVIDIA
Chip type: GeForce 8800 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0611&SUBSYS_23331682&REV_A2
Display Memory: 2544 MB
Dedicated Memory: 497 MB
Shared Memory: 2046 MB
Current Mode: 1152 x 864 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: nvd3dumx.dll,nvd3dum,nvwgf2umx.dll, nvwgf2um
Driver Version: 7.15.0011.7519 (English)
DDI Version: 10
Driver Attributes: Final Retail
Driver Date/Size: 5/16/2008 14:01:00, 8115712 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4551-11CF-6D68-380302C2CA35}
Vendor ID: 0x10DE
Device ID: 0x0611
SubSys ID: 0x23331682
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{B338D50D-A64A-4790-AC01-475B64252A78}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10DE0175&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.5559 (English)
WHQL Logo'd: Yes
Date and Size: 1/30/2008 11:37:18, 1354784 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek HDMI Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Realtek Digital Output (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Realtek Digital Input (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 1/20/2008 19:47:01, 270336 bytes
| Driver: usbd.sys, 1/20/2008 19:47:25, 7680 bytes
+-+ Microsoft USB IntelliMouse Optical
| | Vendor/Product ID: 0x045E, 0x0039
| | Matching Device ID: usb\vid_045e&pid_0039
| | Service: HidUsb
| | Driver: hidusb.sys, 1/20/2008 19:46:55, 15872 bytes
| | Driver: hidclass.sys, 1/20/2008 19:46:55, 48640 bytes
| | Driver: hidparse.sys, 1/20/2008 19:46:55, 31616 bytes
| | | Matching Device ID: hid\vid_045e&pid_0039
| | | Service: mouhid
| | | Driver: mouhid.sys, 1/20/2008 19:46:59, 19968 bytes
| | | Driver: mouclass.sys, 1/20/2008 19:46:59, 39992 bytes
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 1/20/2008 19:47:27, 64000 bytes
| Driver: kbdclass.sys, 1/20/2008 19:47:27, 42040 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 1/20/2008 19:46:50, 63544 bytes
| Driver: sermouse.sys, 1/20/2008 19:46:59, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 23.6 GB
Total Space: 58.2 GB
File System: NTFS
Model: ST325031 0AS SCSI Disk Device
Drive: X:
Free Space: 10.8 GB
Total Space: 11.6 GB
File System: NTFS
Drive: Y:
Free Space: 157.4 GB
Total Space: 168.7 GB
File System: NTFS
Drive: D:
Model: HL-DT-ST RW/DVD GCC-4480B ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:54, 79872 bytes
System Devices
Name: NVIDIA GeForce 8800 GT
Device ID: PCI\VEN_10DE&DEV_0611&SUBSYS_23331682&REV_A2\6&37DCA6B6&0&00000018
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 9572000 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 8115712 bytes
Driver: C:\Windows\system32\nvapi64.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 642560 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 3826688 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 5689344 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 442368 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 2360832 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 12773376 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 9039872 bytes
Driver: C:\Windows\system32\nvcpl.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 15843872 bytes
Driver: C:\Windows\system32\nvsvc64.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 552992 bytes
Driver: C:\Windows\system32\nvsvcr.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 795136 bytes
Driver: C:\Windows\system32\nvmctray.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 82464 bytes
Driver: C:\Windows\system32\nvdisps.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 6913568 bytes
Driver: C:\Windows\system32\nvgames.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 5009440 bytes
Driver: C:\Windows\system32\nvmccss.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 289824 bytes
Driver: C:\Windows\system32\nvmobls.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 1636384 bytes
Driver: C:\Windows\system32\nvvitvs.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 4310560 bytes
Driver: C:\Windows\system32\nvmccs.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 265248 bytes
Driver: C:\Windows\system32\nvmccsrs.dll, 7.15.0011.7519 (Arabic), 5/16/2008 14:01:00, 35328 bytes
Driver: C:\Windows\system32\nvwss.dll, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 3164704 bytes
Driver: C:\Windows\system32\nvcolor.exe, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 181792 bytes
Driver: C:\Windows\system32\nvudisp.exe, 1.03.0011.0000 (English), 5/16/2008 14:01:00, 493568 bytes
Driver: C:\Windows\system32\nvvsvc.exe, 7.15.0011.7519 (English), 5/16/2008 14:01:00, 161792 bytes
Driver: C:\Windows\system32\nvwsapps.xml, 5/16/2008 14:01:00, 26566 bytes
Driver: C:\Windows\system32\nvapps.xml, 6/11/2008 14:48:44, 188960 bytes
Driver: C:\Windows\system32\nvdisp.nvu, 5/16/2008 14:01:00, 8360 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 12/11/2007 02:06:00, 930272 bytes
Driver: C:\Windows\help\nvcpl\nvdsp.chm, 5/16/2008 14:01:00, 181895 bytes
Driver: C:\Windows\help\nvcpl\nv3d.chm, 5/16/2008 14:01:00, 116384 bytes
Driver: C:\Windows\help\nvcpl\nvmob.chm, 12/11/2007 02:06:00, 54988 bytes
Driver: C:\Windows\help\nvcpl\nvwks.chm, 5/16/2008 14:01:00, 261806 bytes
Driver: C:\Windows\nvtmpinst\nvcpl.cpl, , 0 bytes
Driver: C:\Windows\nvtmpinst\nvcplui.exe, , 0 bytes
Driver: C:\Windows\nvtmpinst\nvexpbar.dll, , 0 bytes
Driver: C:\Windows\nvtmpinst\nvcpl.chm, , 0 bytes
Driver: C:\Windows\SysWow64\nvapps.xml, 6/11/2008 14:48:44, 188960 bytes
Driver: C:\Windows\system32\nvcod.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 126464 bytes
Driver: C:\Windows\system32\nvcod130.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 126464 bytes
Driver: C:\Windows\system32\nvcodh.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 126464 bytes
Driver: C:\Windows\system32\nvcodhins.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 126464 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_05B1&SUBSYS_0C1910DE&REV_A2\4&15F80C0A&0&0018
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:51, 179768 bytes
Device ID: PCI\VEN_10DE&DEV_05B1&SUBSYS_00000000&REV_A2\5&1AC68B5B&0&100018
Device ID: PCI\VEN_10DE&DEV_05B1&SUBSYS_00000000&REV_A2\5&1AC68B5B&0&000018
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03BC&SUBSYS_10003842&REV_A1\3&2411E6FE&0&11
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03BB&SUBSYS_0C5510DE&REV_A1\3&2411E6FE&0&38
Device ID: PCI\VEN_10DE&DEV_03BA&SUBSYS_10003842&REV_A1\3&2411E6FE&0&12
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B7&SUBSYS_0C5510DE&REV_A1\3&2411E6FE&0&18
Device ID: PCI\VEN_10DE&DEV_03B6&SUBSYS_10003842&REV_A1\3&2411E6FE&0&10
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B5&SUBSYS_10003842&REV_A1\3&2411E6FE&0&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B4&SUBSYS_10003842&REV_A1\3&2411E6FE&0&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B3&SUBSYS_10003842&REV_A1\3&2411E6FE&0&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B2&SUBSYS_10003842&REV_A1\3&2411E6FE&0&0D
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B1&SUBSYS_10003842&REV_A1\3&2411E6FE&0&0C
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B0&SUBSYS_10003842&REV_A1\3&2411E6FE&0&0B
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AF&SUBSYS_10003842&REV_A1\3&2411E6FE&0&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AE&SUBSYS_10003842&REV_A1\3&2411E6FE&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AD&SUBSYS_10003842&REV_A1\3&2411E6FE&0&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AC&SUBSYS_10003842&REV_A1\3&2411E6FE&0&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AB&SUBSYS_10003842&REV_A1\3&2411E6FE&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AA&SUBSYS_10003842&REV_A1\3&2411E6FE&0&02
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A9&SUBSYS_10003842&REV_A1\3&2411E6FE&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A8&SUBSYS_10003842&REV_A2\3&2411E6FE&0&05
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_03A3&SUBSYS_10003842&REV_A2\3&2411E6FE&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0272&SUBSYS_10003842&REV_A3\3&2411E6FE&0&52
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_10003842&REV_A2\3&2411E6FE&0&48
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&0&80
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_10003842&REV_A3\3&2411E6FE&0&59
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6001.18000 (English), 1/20/2008 19:47:25, 49152 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6001.18000 (English), 1/20/2008 19:47:25, 259584 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6001.18000 (English), 1/20/2008 19:47:01, 270336 bytes
Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16386 (English), 11/2/2006 04:17:29, 10752 bytes
Driver: C:\Windows\system32\hcrstco.dll, 6.00.6001.18000 (English), 1/20/2008 19:47:25, 17920 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_10003842&REV_A3\3&2411E6FE&0&58
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.00.6001.18000 (English), 1/20/2008 19:47:25, 24064 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_026C&SUBSYS_10003842&REV_A2\3&2411E6FE&0&81
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6001.17036 (English), 1/20/2008 19:46:51, 50688 bytes
Name: NVIDIA nForce Networking Controller #2
Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_10003842&REV_A3\3&2411E6FE&0&A0
Driver: n/a
Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_0267&SUBSYS_10003842&REV_A1\3&2411E6FE&0&78
Driver: C:\Windows\system32\DRIVERS\nvstor64.sys, 10.03.0000.0042 (English), 8/18/2008 19:00:00, 170528 bytes
Driver: C:\Windows\system32\nvraidco.dll, 10.03.0000.0042 (English), 8/18/2008 19:00:00, 402464 bytes
Driver: C:\Windows\system32\nvraiins.dll, 10.03.0000.0042 (English), 8/18/2008 19:00:00, 402464 bytes
Driver: C:\Windows\system32\NvRCoAr.dll, 10.03.0000.0042 (Arabic), 8/18/2008 19:00:00, 16928 bytes
Driver: C:\Windows\system32\NvRCoCs.dll, 10.03.0000.0042 (Czech), 8/18/2008 19:00:00, 16928 bytes
Driver: C:\Windows\system32\NvRCoDa.dll, 10.03.0000.0042 (Danish), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoDe.dll, 10.03.0000.0042 (German), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoEl.dll, 10.03.0000.0042 (Greek), 8/18/2008 19:00:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoEng.dll, 10.03.0000.0042 (English), 8/18/2008 19:00:00, 16928 bytes
Driver: C:\Windows\system32\NvRCoENU.dll, 10.03.0000.0042 (English), 8/18/2008 19:00:00, 16928 bytes
Driver: C:\Windows\system32\NvRCoEs.dll, 10.03.0000.0042 (Spanish), 8/18/2008 19:00:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoEsm.dll, 10.03.0000.0042 (Spanish), 8/18/2008 19:00:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoFi.dll, 10.03.0000.0042 (Finnish), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoFr.dll, 10.03.0000.0042 (French), 8/18/2008 19:00:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoHe.dll, 10.03.0000.0042 (Hebrew), 8/18/2008 19:00:00, 16416 bytes
Driver: C:\Windows\system32\NvRCoHu.dll, 10.03.0000.0042 (Hungarian), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoIt.dll, 10.03.0000.0042 (Italian), 8/18/2008 19:00:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoJa.dll, 10.03.0000.0042 (Japanese), 8/18/2008 19:00:00, 15904 bytes
Driver: C:\Windows\system32\NvRCoKo.dll, 10.03.0000.0042 (Korean), 8/18/2008 19:00:00, 15392 bytes
Driver: C:\Windows\system32\NvRCoNl.dll, 10.03.0000.0042 (Dutch), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoNo.dll, 10.03.0000.0042 (Norwegian (Bokmål)), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoPl.dll, 10.03.0000.0042 (Polish), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoPt.dll, 10.03.0000.0042 (Portuguese), 8/18/2008 19:00:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoPtb.dll, 10.03.0000.0042 (Portuguese), 8/18/2008 19:00:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoRu.dll, 10.03.0000.0042 (Russian), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoSk.dll, 10.03.0000.0042 (Slovak), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoSl.dll, 10.03.0000.0042 (Slovenian), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoSv.dll, 10.03.0000.0042 (Swedish), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoTh.dll, 10.03.0000.0042 (Thai), 8/18/2008 19:00:00, 16928 bytes
Driver: C:\Windows\system32\NvRCoTr.dll, 10.03.0000.0042 (Turkish), 8/18/2008 19:00:00, 17440 bytes
Driver: C:\Windows\system32\NvRCoZhc.dll, 10.03.0000.0042 (Chinese (Simplified)), 8/18/2008 19:00:00, 14880 bytes
Driver: C:\Windows\system32\NvRCoZht.dll, 10.03.0000.0042 (Chinese (Traditional)), 8/18/2008 19:00:00, 14880 bytes
Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_10003842&REV_A1\3&2411E6FE&0&70
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_10003842&REV_A1\3&2411E6FE&0&68
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.00.6000.16386 (English), 1/20/2008 19:46:50, 13416 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:50, 51256 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:50, 22584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:50, 124472 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_10003842&REV_A3\3&2411E6FE&0&51
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0260&SUBSYS_10003842&REV_A3\3&2411E6FE&0&50
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:51, 17976 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_C55E10DE&REV_00\4&239594EF&0&3880
Driver: C:\Windows\system32\DRIVERS\ohci1394.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:54, 72192 bytes
Driver: C:\Windows\system32\DRIVERS\1394bus.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:54, 65280 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Full Screen Renderer,0x00200000,1,0,,6.06.6001.18063
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
DV Muxer,0x00400000,0,0,,6.06.6001.18000
Color Space Converter,0x00400001,1,1,,6.06.6001.18063
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6001.18063
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6001.18063
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6001.18000
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6001.18000
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6001.18000
MJPEG Decompressor,0x00600000,1,1,,6.06.6001.18063
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6001.18000
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6001.18063
SAMI (CC) Parser,0x00400000,1,1,,6.06.6001.18063
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6001.18000
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Internal Script Command Renderer,0x00800001,1,0,,6.06.6001.18063
MPEG Audio Decoder,0x03680001,1,1,,6.06.6001.18063
DV Splitter,0x00600000,1,2,,6.06.6001.18000
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6001.18063
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
ACM Wrapper,0x00600000,1,1,,6.06.6001.18063
Video Renderer,0x00800001,1,0,,6.06.6001.18063
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6001.18000
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,,6.06.6001.18063
Video Renderer,0x00400000,1,0,,6.06.6001.18063
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6000.16386
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
DVD Navigator,0x00200000,0,3,,6.06.6001.18000
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6001.18000
Record Queue,0x00200000,1,1,WMM2FILT.dll,
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6001.18000
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6001.18000
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6001.18000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6001.18000
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,,6.06.6001.18063
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
AVI/WAV File Source,0x00400000,0,2,,6.06.6001.18063
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6001.18063
MIDI Parser,0x00400000,1,1,,6.06.6001.18063
Multi-file Parser,0x00400000,1,1,,6.06.6001.18063
File stream renderer,0x00400000,1,1,,6.06.6001.18063
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
AVI Mux,0x00200000,1,0,,6.06.6001.18000
Line 21 Decoder 2,0x00600002,1,1,,6.06.6001.18063
File Source (Async.),0x00400000,0,1,,6.06.6001.18063
File Source (URL),0x00400000,0,1,,6.06.6001.18063
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6001.18000
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6000.16386
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6000.16386
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6000.16386
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6001.18000
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6001.18061
MPEG Video Decoder,0x40000001,1,1,,6.06.6001.18063
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6001.18063
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6001.18063
Microsoft ADPCM,0x00200000,1,1,,6.06.6001.18063
GSM 6.10,0x00200000,1,1,,6.06.6001.18063
CCITT A-Law,0x00200000,1,1,,6.06.6001.18063
CCITT u-Law,0x00200000,1,1,,6.06.6001.18063
MPEG Layer-3,0x00200000,1,1,,6.06.6001.18063
Audio Capture Sources:
Realtek Digital Input (Realtek ,0x00200000,0,0,,6.06.6001.18000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6001.18063
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6001.18063
WDM Streaming Capture Devices:
Realtek HD Digital input,0x00200000,1,1,,6.00.6001.18000
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,,6.00.6001.18000
Realtek HDA HDMI Out,0x00200000,1,1,,6.00.6001.18000
Realtek HDA SPDIF Out,0x00200000,1,1,,6.00.6001.18000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6001.18061
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6001.18000
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6001.18061
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6001.18000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6001.18061
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6001.18061
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6001.18061
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,,6.06.6001.18063
Default DirectSound Device,0x00800000,1,0,,6.06.6001.18063
Default WaveOut Device,0x00200000,1,0,,6.06.6001.18063
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,,6.06.6001.18063
DirectSound: Realtek HDMI Output (Realtek High Definition Audio),0x00200000,1,0,,6.06.6001.18063
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,,6.06.6001.18063
Realtek Digital Output (Realtek,0x00200000,1,0,,6.06.6001.18063
Realtek HDMI Output (Realtek Hi,0x00200000,1,0,,6.06.6001.18063
CPU-Z
CPU-Z version 1.47
Processors Map
Number of processors 1
Number of threads 4
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
-- Core 2
-- Thread 0
-- Core 3
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Package Socket 775 LGA (platform ID = 4h)
CPUID 6.F.B
Extended CPUID 6.F
Core Stepping G0
Technology 65 nm
Core Speed 1600.0 MHz (6.0 x 266.7 MHz)
Rated Bus speed 1066.7 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.0x
max VID 1.288 V
Features XD, VT
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008005h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000006FB 0x00040800 0x0000E3BD 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43049
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x0C000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x0C000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x0C004143 0x03C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00000020
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100000
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x51203229 0x20646175 0x20555043 0x51202020
0x80000004 0x30303636 0x20402020 0x30342E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x10008040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 D 32 KB 1 thread(s)
Cache descriptor Level 1 I 32 KB 1 thread(s)
Cache descriptor Level 2 U 4 MB 2 thread(s)
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x000000E8 edx = 0x0000003C eax = 0x65EE365D
MSR 0x00000017 edx = 0x00100000 eax = 0x88408925
MSR 0x000000CD edx = 0x00000000 eax = 0x00000800
MSR 0x0000003F edx = 0x00000000 eax = 0x00000000
MSR 0x000000CE edx = 0x001B0925 eax = 0x7F7F071A
MSR 0x000001A0 edx = 0x00000040 eax = 0x62970481
MSR 0x000000EE edx = 0x00000000 eax = 0x837D4B00
MSR 0x0000011E edx = 0x00000000 eax = 0xBE702109
MSR 0x0000019C edx = 0x00000000 eax = 0x88340000
MSR 0x00000198 edx = 0x09250925 eax = 0x06000925
MSR 0x00000199 edx = 0x00000000 eax = 0x00000925
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008005h
0x00000001 0x000006FB 0x01040800 0x0000E3BD 0xBFEBFBFF
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
MSR 0x000000E8 edx = 0x00000037 eax = 0x1FA46125
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01008005h
0x00000001 0x000006FB 0x02040800 0x0000E3BD 0xBFEBFBFF
MSR 0x000000E8 edx = 0x00000038 eax = 0xE3E6B196
MSR 0x0000019C edx = 0x00000000 eax = 0x88350000
MSR 0x00000198 edx = 0x09250925 eax = 0x06300625
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01008005h
0x00000001 0x000006FB 0x03040800 0x0000E3BD 0xBFEBFBFF
MSR 0x000000E8 edx = 0x00000059 eax = 0xD9137D3F
MSR 0x0000019C edx = 0x00000000 eax = 0x88360000
Chipset
Northbridge NVIDIA nForce 650i SLI SPP rev. A2
Southbridge NVIDIA nForce 650i SLI MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 6144 MBytes
Channels Dual
Memory Frequency 400.0 MHz (2:3)
CAS# 5.0
RAS# to CAS# 6
RAS# Precharge 6
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 24
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) OCZ (7F7F7F7FB0000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number OCZ2RPR8002G
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 333 400
CAS# 4.0 5.0
RAS# to CAS# delay 5 6
RAS# Precharge 5 6
TRAS 15 18
TRC 20 24
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 4.0 5.0
RAS# Precharge 5 6
TRAS 15 18
TRC 20 24
DIMM #3
General
Memory type DDR2
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 1024 MBytes
Part number CM2X1024-6400C4
Attributes
Number of banks 1
Data width 64 bits
Correction None
EPP yes (1 profiles)
XMP no
Timings table
Frequency (MHz) 270 400
CAS# 4.0 5.0
RAS# to CAS# delay 4 5
RAS# Precharge 4 5
TRAS 13 18
TRC 15 22
EPP profile 1 (full)
Voltage level 2.100 Volts
Address Command Rate 2T
Cycle time 2.500 ns (400.0 MHz)
tCL 4.0 clocks
tRCD 4 clocks (10.00 ns)
tRP 4 clocks (10.00 ns)
tRAS 12 clocks (30.00 ns)
tRC 102 clocks (255.00 ns)
tWR 26 clocks (63.75 ns)
DIMM #4
General
Memory type DDR2
Size 1024 MBytes
Attributes
Number of banks 1
Data width 64 bits
Correction None
XMP no
Timings table
CAS# 4.0 5.0
RAS# Precharge 4 5
TRAS 13 18
TRC 15 22
tCL 4.0 clocks
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 08 70 01 02 00 07 30 50 3D 60 3C 1E 3C 2D 01
20 17 25 05 12 3C 1E 1E 00 06 3C 70 80 14 1E 00 00
30 00 03 00 00 00 00 00 00 00 00 00 00 00 00 10 EE
40 7F 7F 7F 7F B0 00 00 00 02 4F 43 5A 32 52 50 52
50 38 30 30 32 47 20 20 20 20 20 20 02 AC 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 08 08 12 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dump Module #2
Dump Module #3
00 80 08 08 0E 0A 60 40 00 05 25 40 00 82 08 00 00
10 0C 08 30 03 02 00 03 37 50 00 00 32 1E 32 2D 01
20 18 25 05 13 3C 1E 1E 00 00 37 69 80 14 1E 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 F0
40 7F 7F 9E 00 00 00 00 00 01 43 4D 32 58 31 30 32
50 34 2D 36 34 30 30 43 34 20 20 20 20 20 00 00 00
60 00 00 00 6D 56 4E B1 21 FF FF FF FF FF FF FF FF
70 FF FF FF FF 8C 50 01 20 25 25 10 28 28 1E FF FF
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dump Module #4
Monitoring
Mainboard Model nForce 750i SLI (0x48A - 0xCC64B61C)
LPCIO
Vendor Winbond
Model W83627DHG
Vendor ID 0x5CA3
Chip ID 0xA0
Revision ID 0x25
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0xB
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 A0 25 FF 00 14 00 00 FF 50 00 7E C0 EA 21 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Winbond W83627DHG hardware monitor
Voltage sensor 0 1.19 Volts [0x95] (CPU VCORE)
Voltage sensor 1 6.58 Volts [0x76] (+12V)
Voltage sensor 2 3.31 Volts [0xCF] (AVCC)
Voltage sensor 3 3.30 Volts [0xCE] (+3.3V)
Voltage sensor 4 1.19 Volts [0x95] (VIN1)
Voltage sensor 5 4.75 Volts [0xC6] (+5V)
Voltage sensor 6 1.85 Volts [0xE7] (VIN3)
Temperature sensor 0 85°C (184°F) [0x55] (SYSTIN)
Temperature sensor 1 46°C (113°F) [0x5B] (CPUTIN)
Temperature sensor 2 39°C (101°F) [0x4D] (AUXTIN)
Fan sensor 1 2679 RPM [0x3F] (CPUFANIN0)
Dump hardware monitor
LPC Register space, base address = 0x0290
bank 0
00 04 FF 04 E7 31 00 28 10 01 BF 01 BF 3C 3C 0A 0A
10 04 FF 50 00 00 01 01 3C 43 07 00 00 FF FF FF DA
20 95 76 CF CE 95 C6 E7 55 FF 3F FF DA 00 61 76 E5
30 0B EC 0E A2 58 63 15 55 C7 00 7F E6 07 00 3B FF
40 01 D2 1E FF FF FF 07 D4 2D 00 40 44 18 15 00 A3
50 FF FF 00 FF FF FF 00 00 C1 03 FF FF 00 05 04 05
60 04 BF 30 32 BF BF 3C FF 08 FF 08 FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 04 FF 04 E7 31 00 28 10 01 BF 01 BF 3C 3C 0A 0A
90 04 FF 50 00 00 01 01 3C 43 07 00 00 FF FF FF DA
A0 95 76 CF CE 95 C6 E7 55 FF 3F FF DA 00 61 76 E5
B0 0B EC 0E A2 58 63 15 55 C7 00 7F E6 07 00 3B FF
C0 01 00 10 FF FF FF 07 D4 2D 00 40 44 18 15 00 A3
D0 FF FF 00 FF FF FF 00 00 C1 03 FF FF 00 05 04 05
E0 04 BF 30 32 BF BF 3C FF 08 FF 08 FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 1
50 2D 00 02 00 00 7F 07 E2 FF FF FF FF FF FF FF FF
bank 2
50 26 80 02 00 00 7F 06 00 FF FF FF FF FF FF FF FF
bank 3
50 02 03 01 07 03 03 03 01 06 01 00 A0 2F 02 00 00
bank 4
50 3B 13 FF 00 00 00 00 05 31 C2 1C BB 09 5D 20 7F
bank 5
50 CF C2 09 FF 8D 80 62 00 08 47 00 00 A9 00 00 00
Hardware monitor
Voltage sensor 3 3.31 Volts [0xCF] (+3.3V)
SMBus Register space, base address = 0x01C80
SMBus request at channel 0x0, address 0x2D
bank 0
10 04 FF 50 00 00 01 01 3C 43 07 00 00 FF FF FF D2
20 95 76 CF CF 95 C6 E7 55 FF 3F FF DA 00 61 76 E5
40 01 10 10 FF FF FF 07 D4 2D 00 40 44 18 15 00 A3
90 04 FF 50 00 00 01 01 3C 43 07 00 00 FF FF FF D6
A0 94 76 CF CE 95 C6 E7 55 FF 3F FF DA 00 61 76 E5
C0 01 10 10 FF FF FF 07 D4 2D 00 40 44 18 15 00 A3
bank 1
50 2C 80 02 00 00 7F 07 E2 FF FF FF FF FF FF FF FF
bank 2
bank 3
50 03 02 01 00 03 03 03 01 06 01 00 A0 2F 02 00 00
bank 4
50 00 13 FF 00 00 00 00 03 73 C2 1C BB 09 5D 20 7F
bank 5
Hardware monitor
Intel Core 2 Quad Q6600 hardware monitor
Temperature sensor 0 48°C (118°F) [0x34] (Core #0)
Temperature sensor 1 48°C (118°F) [0x34] (Core #1)
Temperature sensor 2 47°C (116°F) [0x35] (Core #2)
Temperature sensor 3 46°C (114°F) [0x36] (Core #3)
Hardware monitor
GeForce 8800 GT hardware monitor
Temperature sensor 0 65°C (148°F) [0x41] (GPU Core)
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03A3
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x3842
Subsystem ID 0x1000
Int. Line 0x00
Int. Pin 0x00
Capabilities
HyperTransport Capability
Offset 40h
Revision 0.16
Interface type Host/Secondary
Device number 0
Link 0 width (in/out) 8 bits/8 bits
Link 0 frequency 1000MHz
Dump
00 DE 10 A3 03 06 00 B0 00 A2 00 00 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 42 38 00 10
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
40 08 00 01 20 22 00 00 00 10 26 3F 00 03 01 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 21 49 44 44 13 01 00 00 00 00 00 00 10 00 00 00
70 07 05 22 00 00 00 00 00 81 01 85 01 00 00 00 00
Reply to Mushroomjane
- 0 +
try this:
7. "Conflict with Emulation Software Detected"
- Open the Game DVD in your drive (DVD) or go to the directory where your installation is located (EA Download Manager).
- Open the Binari~1.cab (Bin32) or Binari~2.cab (Bin64) with WinRar or a similar pack-program and copy the Crysis.exe file.
- Place it into your installation directory of Crysis\Bin32 or Crysis\Bin64 and replace the existing .exe file.
it fixed my black screen issue. i dont have nvidia network controller.
good luck
http://www.crymod.com/thread.php?threadid=15318
Reply to sesam2k
thanks tried that, about to try the rest of the solutions they have on that site, although your solution didnt work for me. I'm curious as what the connection is between dark messiah and crysis but not quake wars.. if i could figure that out id be getting somewhere. But i dont get any errors screens just a frozen computer that i have to hard boot
Not one of those solutions on that link worked for me. Thanks for trying.
There are 1200 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
