Archived from groups: alt.internet.wireless (More info?)
Hey all,
I want to setup a wireless network between 3 computers. I want each
computer to have access to the Internet so I'm thinking that I need a
wireless router and wireless network cards.
The problem I'm having is I don't really know much about routers, or
networking (only basic knowledge).
What should I be looking for in a router when I'm shopping around?
I've also heard a lot about the security of wireless networks, and people
from outside your house can gain access to the network easily. Is this true,
or is this just because those people haven't setup the network/router
correctly?
Do all the computers need to be running the same OS? Two are running Windows
XP and the other Windows ME. Will this cause a problem when networking them
together?
One more thing, because the Internet connection is being shared, does that
mean that each computer is set a bandwidth or does it adjust itself
according to demand by the computer?
One computer is used a lot on the Internet, and the other two will only be
used a few times a week.
I live in the UK, so if anyone has any recommendations of where to buy a
router and equipment needed in the UK that would be helpful.
Thanks for any help,
Global_Killa
"You're a victim of the rules you live by!"
Sponsored Links
"Global_Killa" <global_killa@hotmail.com> wrote in message
news:cgg896$etc$1@newsg1.svr.pol.co.uk...
> Hey all,
true,
> correctly?
Windows
them
> together?
> Global_Killa
I think you should do a goodle search on Wireless internet and do a bit of
reading.
Bob Alston
bobalston9 AT aol DOT com
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.742 / Virus Database: 495 - Release Date: 8/19/2004
Reply to Anonymous
If you only want shared internet access, then you only need to purchase a
wireless router. Most routers comes with 4 LAN ports to connect each PC
with an ethernet cable in case you don't have the money to go completely
wireless and/or if you have a LAN card in each PC. In reference to what
kind, that's up for grabs. There's PROS and CONS to each brand. The most
popular is Linksys, followed by Netgear, D-Link and Belkin. They are all
consumer grade brands. Buffalo and SMC are also brands to consider. To
save you a bunch of grief, I do recommend that you stick with one brand.
They are designed to work together. Mixing brands can sometimes be a
problem. Go with the "wireless G" type. What to look for?: Warranty Life,
WPA / WPA-PSK encryption, customer satisfaction, NAT firewall, logging
features, the ability to expand, parental controls, and ease of use to
name a few. Personnally, I've tried Linksys, Netgear and Belkin. Linksys
was loaded with features, but kept dropping signals. Netgear was the
easiest to set up and use, but needed frequent reboots and the Belkin is
loaded, easy to setup and use and has not given me any problems.
Remember, these are my experiences only. They could've have simply been
lemons. Anyway, I hope this helps you. Take care.
news:cgg896$etc$1@newsg1.svr.pol.co.uk:
> Hey all,
> each
> people from outside your house can gain access to the network easily.
> Is this true, or is this just because those people haven't setup the
> network/router correctly?
> Windows XP and the other Windows ME. Will this cause a problem when
> networking them together?
> that mean that each computer is set a bandwidth or does it adjust
> itself according to demand by the computer?
> only be used a few times a week.
> a router and equipment needed in the UK that would be helpful.
Reply to Anonymous
Global Killa,
I can answer one of your questions. I have PC's with Win 95a, Win98,
and Win XP Pro all networked together (three wired and two wireless).
No problem with different operating systems seeing each other.
Scott
Global_Killa wrote:
> Hey all,
> correctly?
> together?
> Global_Killa
Reply to Scott
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wireless Network Help
There are 1180 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
