ABIT KX7-333 problem
Phantom_uk
HELP!!!
Every time I startup my pc, after a few minutes the screen freezes and I then get a blue screen, I restart the PC and then it is fine until it is turned off again for a period of time. I thought it could have been a driver problem until the other day when I was in the BIOS and it even locked up in there? Could it be a problem with the RAM?
I am running the following:
Athlon XP1900+ on ABIT KX7-333
128 meg PC2100 DDR (ebuyer)
Geforce2mx 32meg
Creative 5.1 live
I have tried everything that the windows help suggests, I took out all my PCI cards and it still froze, I even tried changing the video card, which is why I think it could be the memory? Has anyone else encountered similar problems?
Phantom_uk
The screen freezes and after a few seconds I get the blue screen, it says windows has been shut down to prevent damage to the computer and normally says IRQ_NOT_LESS_OR_EQUAL, but sometimes says other stuff or nothing at all, a file is saved in the minidump file every time it happens. My power supply is standard 300w
Kurisu
5
Did you clear the BIOS? You say it freezes there, so maybe you messed with a setting or two. That's my best guess. :)
-This Signature for Rent-
