Annoying System Sound
Forum Windows XP : Windows XP General Discussion - Annoying System Sound
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
There is one sound that the system makes that I would like to eliminate or
change. I originally thought that it was a mechanical sound in the keyboard.
It is a clicking sound that the system makes after a mouse click, page
change, etc. I've discovered a sound in the sounds control panel that sounds
like it. It is "Windows XP Start". I can't find it assigned to any action.
Does anyone know what I am referring to? It is really a system sound or an
actual click in the keyboard?
Dennis M. Marks
Sponsored Links
Control Panel> Sounds and Audio> Sounds> Program Events: Under Windows
Explorer change "Start Navigation" to none.
Sharon F
MS-MVP ~ Windows Shell/User
Reply to Anonymous
If you just mean a loud click, that's probably the Navigation sound.
Can be turned off at Control Panel \ Sounds and Audio \ Sounds tab,
located far down under Windows Explorer. It's easy enough to turn off,
but mine keeps coming back after a while.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Annoying System Sound
There are 1134 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
