Tom's Hardware > Forum > Old Man/Woman's Club > Other > shutdown problem
shutdown problem
Forum Old Man/Woman's Club : Other - shutdown problem
I recently bought a Abit KG7 Mobo with a Athlon XP 1900 1.6GHZ CPU both retail, the CPU has a running temp of about 135 F. I am running Windows ME with Micron Memory 2 @ 256MB DDR 2100, I have a 420 watt turboline switching power supply. I am having a problem with the shutdowns intermittently. If I leave the PC on all night the system appears to go into some kind of hibernation mode or just plan locks up and the monitor goes blank, the keyboard locks, the power button and the reset buttons do not work. I have to kill the power at the power supply to get the system back. Occasionally when shutting down windows instead of powering off, the system restarts itself. I have turned off power management in windows and looked in the BIOS (which is the latest (4-02-02 761-686B-6A6S6A1AC-68.) to see if there is a setting to stop the system from powering off after shutting down windows. I could not find a setting. I have troubleshot this problem to death with no success. I was hoping someone might have an idea about a solution to this problem? I realize that this could be bad mem or power or Mobo or CPU but was hoping someone might have ran into the same problem.
Any help would be greatly appreciated.
<P ID="edit"><FONT SIZE=-1><EM>Edited by ufowatcher on 04/30/02 00:00 AM.</EM></FONT></P>
Sponsored Links
Your components sound good, but the OS bothers me. Have you reinstalled the OS and still had the same problem? I'd love for this to just be a software problem so that you can resolve it easily.
I should however note that it might be your temps. At 57C, you're a bit too high. Take the cover off the case(side panel) and blow a fan on the system. If it doesn't lock up and cause problems anymore, then you'll want to improve your airflow and cooling.
<font color=red>God</font color=red> <font color=blue>Bless</font color=blue> <font color=red>America!</font color=red>
Reply to dhlucke
Thanks for the tips, I took cooling into consideration when I built the PC about a week ago, I have 2 case fans one sucking air in and one blowing out, the power supply also draws air out of the system, the CPU was retail and came with the fan and heat sync from AMD, but I do agree that the temps are about 10f to high. I might try a dual boot with XP and see if it does it with XP running.
thanks again
Reply to Anonymous
- 0 +
Just as an example, one of the systems I built had problems at 49C, but was fine at 47C. Mine runs in the upper 30's to lower 40's. You should try to drop the temps, temporarely at least, to see if it's the problem.
Reply to dhlucke
- 0 +
<A HREF="http://www.viahardware.com/faq/kg7kr7/kg7kr7faq.htm" target="_new"><b>Here</b></A> is a good site for you MB and maybe you can find your answer.
:smile: <b><font color=blue> I took an I.Q. test today...It came back negative.</font color=blue></b> :lol:
Reply to OldBear
- 0 +
You can check your voltages to see if it is caused by a bad powersupply.
I have the KG7 running with Win98 and I don't have those problems.
<b>THGC:</b> before: :frown: :eek: , after: :smile: :cool: .
Reply to svol
There are 1267 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
