Annoying Problem
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
The drop down history in the "run" command on the start menu continually clears
by itself. I would like it to retain the history of frequently run programs.
Does anyone know the cause or a fix?
Windows XP Pro Service Pack 2.
2 answers Last reply
More about annoying problem
  1. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    "Michael Meyers" <meyers@shaw.ca> wrote in message
    news:vcfcs090cjlv9bc91c7cl62gq2joj3pibp@4ax.com
    > continually clears by itself. I would like it to retain the history
    > of frequently run programs. Does anyone know the cause or a fix?
    If you are clearing history in IE, that will clear the Run history too.
    Frank Saunders, MS-MVP, IE/OE
    Please respond in Newsgroup only. Do not send email
    http://www.fjsmjs.com
    Protect your PC
    http://www.microsoft.com/security/protect/
  2. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    On Mon, 20 Dec 2004 06:10:49 -0600, "Frank Saunders, MS-MVP"
    <franksaunders@mvps.org> wrote:
    I have I.E. properties set to keep history for 10 days, but I never manually
    clear the history.
    Any other ideas of what could be causing this?
Command Prompt Microsoft Windows XP
