Problems running XP upgrade
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I have recently tried to upgrade from Windows ME to XP.
After several unsuccessful attempts to actually get it installed, I believed
I had managed, as XP loaded once (the upgrade CDROM was still in the drive,
and I now wonder whether it simply booted from that). Each time I attempt to
start the PC now, I get the message that windows needs to check the files,
for something to do with FAT32 (this is prior to windows loading). I allowed
this to run through - which took about 48 hours, and it told me that it had
repaired several files etc, then rebooted - and gave me exactly the same
message. If I cancel the check, the PC simply reboots again - and provides
the same message, and when I run the check (which now completes within a few
minutes), it again just reboots, so I can't actually get it to run windows.
I don't know whether it is linked, but I ran Scandisk in ME, as it prompted
me to each time I loaded, and this too took around 48 hours to complete. Is
this likely to be an error on the Hard Drive? I can however reinstall ME,
and it works perfectly now.
Does anyone have any suggestions about how I can get over this problem?
G
Guest
Guest
A computer needs to be prepared properly for installation of
a new operating system, whether it is an upgrade from 98/ME
or an update to SP2.
Some steps should be taken to prevent problems, such as
removing some incompatible software, disabling anti-virus
off or uninstalling it, removing some hardware and the
drivers, such as printers, scanners so that the proper XP
drivers will install when you complete the OS upgrade and
reinstall the hardware.
There are hardware and software compatibility checks. Start
with
this
http://www.microsoft.com/windowsxp/home/upgrading/default.mspx
read
http://support.microsoft.com/default.aspx?scid=kb;en-us;316941
and see
http://www.microsoft.com/windowsxp/using/setup/default.mspx
Merry Christmas
Have a Safe and Happy New Year
Live Long and Prosper
Jim Macklin
"Aradia" <Aradia@discussions.microsoft.com> wrote in message
news:24A3899D-E38E-413F-B9C8-5F1221B0D2CE@microsoft.com...
still in the drive,
check the files,
loading). I allowed
told me that it had
exactly the same
it to run windows.
ME, as it prompted
this problem?
G
Guest
Guest
See former MVP Gary Woodruff's article on upgrading to XP at
http://aumha.org/win5/a/xpupgrad.htm
Do you need to upgrade your existing WindowsMe installation to
preserve installed applications etc? If not then it is possible to
do a clean install of XP using the Upgrade disk and then reinstall
your application programs and restore your data files from backups.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
"The reason computer chips are so small is computers don't eat much."
G
Guest
Guest
How to Troubleshoot Windows XP Problems During Installation
http://support.microsoft.com/default.aspx?scid=kb;EN-US;310064
How to troubleshoot problems during installation when you upgrade from
Windows 98
or Windows Millennium Edition to Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;310064&Product=winxp
Troubleshooting Windows XP Setup
http://www.kellys-korner-xp.com/xp_setup.htm
[Courtesy of MS-MVP Kelly Theriot]
Carey Frisch
Microsoft MVP
Windows XP - Shell/ User
Dec 2004
HTH,
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
http://www.microsoft.com/athome/security/protect/default.aspx
Your cooperation is very appreciated.
believed
drive,
to
allowed
had
provides
few
windows.
prompted
Is
