power consumption
Forum Wireless Networking : Wireless General Discussions - power consumption
Archived from groups: alt.internet.wireless (More info?)
Hi,
I'm trying to compare the mini-pci in my laptop (an intel "Calexico
II" which is the oem put in gateway laptop, specs here:
http://tinyurl.com/679fj ) with another one i have sitting around my
house (the Netegriti a/b/g, specs here: http://tinyurl.com/6lsu3 )
wireless cards. I can't find a way to compare the power consumption
though, one is expressed as MA and one as watts. I have looked all
around the net, but no help. Can anyone here lend a hand?
thx,
dan
Sponsored Links
On 27 Aug 2004 02:04:37 -0700, harryguy082589@aol.com (Dan Irwin)
The Mini-PCI card runs on 3.3 volts DC power.
Watts = Volts * Amps
In this case, just multiply the one expressed in MilliAmps times 3.3V
to equal milliwatts. There seem to be quite a few numbers, so I'll
let you do the math.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
In article <o9lui0lcv94452nv7gjm8ilm6inokoonfh@4ax.com>,
Jeff Liebermann <jeffl@comix.santa-cruz.ca.us> wrote:
:The Mini-PCI card runs on 3.3 volts DC power.
: Watts = Volts * Amps
:In this case, just multiply the one expressed in MilliAmps times 3.3V
:to equal milliwatts.
A card that runs on 3.3 volts DC is supplied with 3.3V, but it does
not necessarily -use- all of that power. When it comes to radio
transmissions, it might only use a fraction of that power for
the transmittor, with whatever of the rest is used going into running
the dsp/cpu/prom/whatever . Thus 3.3 V * the milliamps rating
might give an unrealistically high power rating, perhaps even off by
an order of magnitude.
Live it up, rip it up, why so lazy?
Give it out, dish it out, let's go crazy, yeah!
-- Supertramp (The USENET Song)
Reply to Anonymous
On 27 Aug 2004 16:14:59 GMT, roberson@ibd.nrc-cnrc.gc.ca (Walter
I beg to differ. The ratings that were in question are the power
consumption. Whether the radio turns the power into RF or smoke is of
no concern. The power is consumed (assuming a constant 3.3vdc input
voltage). If you look at the URL's previously posted, the power
consumption specs are broken down into standby, rx, tx, power save,
and such. Each has it's own power consumption level. With a constant
DC input voltage (3.3VDC), you can express power consumption in either
watts (milliwatts), or amps (milliamps).
Also, your statement of "a card runs on 3.3 volts DC.....but does not
necessarily -use- all of that power" is a misnomer. Power is measured
in watts, not volts. Are you suggesting that the card does not use
all that *VOLTAGE* or something similar? I hope not.
Also, not the title of "Power Consumption". That's consumption, not
power output.
There was no question in the original posting relating to power
efficiency or the method of regulation. As I read it, they were
interested in how much DC power (watts) the two cards burned during
normal operation in order to estimate or extend battery life.
Reply to Anonymous
Jeff Liebermann <jeffl@comix.santa-cruz.ca.us> wrote in message news:<mkrui0l1527qreiuccg23tvogad672k9a1@4ax.com>...
> power output.
Baiscly you hit it. Just wana know which uses more power
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > power consumption
There are 584 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
