Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Possible problem with motherboard
Hello all, i was wondering whether you guys could give me some advice.
I recently left my computer on, unattended for a short period of time. When i returned, the power light remained on,there was no sound from the fans and the monitor was blank. When i unplugged it then, turned it on again (after i had plugged it in ;)) the power light came on, but there was not a sound from the computer (fans etc.)
My fan had been making a noise prior to that, and i was wondering if it would be possible for the fan to break down and then somehow effect the motherboard?
I am completely stumped and am not sure where to begin looking or testing.
Suggestions and advice will be much appreciated,
Thanks Al
Sponsored Links
Well, im not too sure on what your problem might be. But, if by any chance your fans do fail(especially the Heatsink fan) then of course the cpu would fry, and possibly ruin other components in the system. I wish i could help with your problem. good luck
-A7N8X (NON-DELUXE)
-AMD 2100+
-512mb PC3200 Corsair XMS DDR
-GeForce4 Ti4200
-WD 80gig HD
-Windows Xp pro.
Reply to FaMoUs
Did you mean not even any noise from the hard disk drive and floppy drive during power up? Any beep code as well? To check if your CPU is working or not, just let your system runs for a few minutes (or less than a minute if the CPU fan is dead) and then shutdown. The CPU should be warm to touch. I can't think of what else to check... let's see, maybe your PSU has gone bad?
Reply to elzt
absolutely no sound at all, nothing from my DVD, CD, Floppy, or any fans. I havent the slightest clue what is wrong. The only thing that comes on when i turn it on is the power light. Thanks for the suggestions
Reply to MacPhisto84
There are 813 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
