First, the specs.
Athlon 1200
512 MB PC 2100
MSI K7 Master
Leadtek Geforce 2 Pro 64MB
Sound Blaster Live Value
One 40GB and one 6GB drive
Sony Cd rom and Lite on CD-R
SMC network, AOpen modem
The thing has a serious problem with crashing in some games, especially when loading or just after a load. THe same problem occurs with my Uncle's Geforce 2 in my machine, so I don't think it's video card. I've also tried many driver versions on several O/Ses.
Three main points, however:
1. The motherboard heatsink is hot. I can probably get a bigger one if this is a problem. The northbridge is an AMD 760 chip.
2. PSU voltage shows up fine on most voltages, but the 12V line shows up as 12.5 in the monitor. The game runs fine sometimes but not others, so I'm not sure if this is a problem.
2. I noticed the problems occur more with my set up than at my uncles or the computer store I got it from, so I'm wondering if my old surge protector is affecting the power a bit.
When at home, it often crashes first try (using old surge protector for home setup), but when I'm using it at other locations, it often takes many tries to get it to crash in a load.
Suggestions? I've been trying at this problem for months, any help would be appreciated.
Athlon 1200
512 MB PC 2100
MSI K7 Master
