Latest Reviews & Articles
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
AMD Athlon II X2 / Phenom II X2 And Low-Power CPU Bonanza
Eager to let you know it’s been busy, AMD is launching four new processors today: the first Athlon II, a dual-core Phenom II, and two low-power 65W Phenom IIs. We bought ourselves a new Pentium E6300 and let loose with AMD’s latest. Read more
Microsoft’s BPOS: Cloud Computing’s Silver Lining?
Can Microsoft’s Business Productivity Online Suite (BPOS) reignite our hope-strewn love affair with cloud computing? With familiar, cost-effective applications that run on a range of Web browsers, BPOS just might be the Cupid’s arrow that does the trick. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Systems > HP > HP 3570c scanner color problem
Archived from groups: comp.sys.hp.hardware (More info?)
Hi-
I've started getting 2 vertical lines down the right side of the screen
(both on the preview and actual scan). On the right border of the scan there
is a blue stripe and immediately to the left of that is a cyan stripe. In
total, they take up about a fifth of the screen. They used to take up half
of the screen, but I noticed the metal clip that held a mirror in place was
broken, so I hot-glued the mirror back in place. The color balance of the
rest of the scan is off, also, being shifted towards the blue. I uninstalled
and re-installed the drivers, and cleaned both sides of the glass, as
recommended by HP support. Is there any hope for this scanner?
Thanks,
heymikey
There are 800 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
