Several things to keep in mind:
- At least one spot for a fan in front and back. You may want more, depending. Some also come with a fan mount in front of the hard drives. It should come with sufficient room for air intake through the front, or you may have to cut your own.
- Do you want it to come with front USB ports?
- Do you want it to come with a power supply, or will you buy one separately? Either way, make sure it's quality.
- Are you going to carry it to LAN parties or anything, or will it sit in the same spot? This may affect how big&heavy a case you want.
- Do you want to have one that's nice and shiny out of the box, like aluminum, or just a crappy beige one that you can paint yourself (like me)?
- How many of each type of drive bay do you want?
- Do you want removable drive cages and/or drive rails?
- Do you want a window on the side, so you can put all sorts of lights inside like lots of folks are doing these days?
- Try not to get one with sharp edges.
- You may want to try and find one that you can check out in person first. Sometimes pictures online aren't enough.
Several favorites around here are Antec/Chieftec, Lian Li, Atlas, CoolerMaster, ThermalTake.
I'm sure other folks will chime in with more things to keep in mind.
I think Tom has an article on case selection, if you look.
War Eagle<P ID="edit"><FONT SIZE=-1><EM>Edited by Auburn9698 on 03/13/03 10:42 AM.</EM></FONT></P>
