I just got done putting together my new system with a P4G8X motherboard and I am experiencing problems. Every time I reboot the machine from inside XP, it will hang right before going into POST. I then have to turn off the power and turn it back on, and then the bios screen will come up and say that "During the last boot-up your system hung for an improper CPU speed setting... etc.." Also, sometimes it will hang during POST and the voice prompt will say "System boot failure due to CPU overclocking" etc.
The problem is, I haven't changed any of the CPU settings to overclock the machine. I am using default settings, and I have checked the settings versus intel's data sheet and they match up perfectly. Sometimes I can twiddle certain settings to get it to boot up or reboot fine for 3 or 4 times, but then it will just happen again.
I'm using a P4 2.53ghz CPU, Radeon 9500 pro, 2x 512mb corsair ddr266 and the P4G8X. I'm really stumped on this, I can't see any of my BIOS settings that could be effecting this, I have tried to change the AGP from 8x to 4x and back again, tried manually setting the CPU settings, tried automatic, same results.. Once it boots up to Windows (usually after power cycling a few times), it will work fine.. But the next time I reboot, same process.
Thanks for any help!!
- durden -
- durden -
