Archived from groups: alt.games.diablo (
More info?)
On Sat, 16 Apr 2005 18:41:04 +0000, Mark wrote:
> "Last2Know" <grokkalot@yahoo.com> wrote in message
> news
an.2005.04.16.17.06.38.122852@yahoo.com...
>> I see the following main options (no particular order):
>> 1) Buff up the bear/wolves with more points in dire wolves or grizzly.
>> My strategy is to think of these pets as decoys and not to expect
>> damage from them.
> The Grizzly is pretty durable. But I really should concentrate on Dire
> Wolves. It doesn't look very good for a Wolf to have a pet bear.
I don't worry much about fashion, but the 3 wolves provide
more distraction for the monsters so long as they stay alive.
>> 2) Put points in Cyclone Armor.
>> 3) Put points in rabies to help kill PIs. Rabies has less
>> pre-reqs for you to get to than Fire Claws. In evaluating it,
>> you need to consider at what skill level you get a better attack
>> against PIs than using Fury's faster attack with the best elemental damage
>> weapon you find (Gimmershred at the high end or something like a 1-400
>> lightning damage wand at the low end). In thinking about that, you
>> need to consider AR issues as well.
> I'm not overly concerned with PIs. I play only in a party and the Sorcs &
> Furyzon can deal with them if the Necros haven't removed it with Amp.
> I was curious about FC simply because I've never tried it, and was wondering
> about it as a possible option for IM areas. At present I just weapon switch
> to a barehanded attack, but it's incredibly slow compared to the Ribcracker.
All of your realistic options will be slow on hell level. If you
are playing with a party and don't intend to do Countess runs solo
then I would just not worry about the PIs. The downside to doing
something like Rabies barehanded on switch is that you lose the
chance for plus skills gear on switch to boost your summons.
Even my untwinked chars often find stuff like Fleshrender or Dark Clan
Crusher or Istlestrike.
Cl
>> 4) Put more points in WW to improve your AR.
> I have a BA merc.
>> 5) Get the Carrion vine to slightly higher level, giving more life per
>> kill and longer survival rate.
> I've never had more than one point in CV for any Druid I've ever played.
> I always considered it a one point wonder. Is it really worth more
> points?
Depends on your plus skills. A twinked char will get it to, say at
least lvl 7 on switch. If your vine is going to only only be at lvl
1 or 2 then more points would help.
I suppose you could also add ravens for the random dim vision casting,
but I tend to stay away from skills that are totally unreliable.
