Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Monitor Power Problems?
I have a Optiquest v73 that flickers. It's not the refresh rate, because it is persistent even at +100MHz. I think that it is a power problem. The outlet I have it plugged into shares the same breaker as my fridge and microwave. When I turn on the microwave, the flickering gets much worse. So I think that it is a inconsistent power or insufficient power issue. Instead of using a cheap power bar should I buy a surge protector to fix this? Or will I have to buy a much more expensive UPS? Or is there a third alternative?
Sponsored Links
Odds are this is NOT a power problem It is most likly a magnetic interferance problem. Move the system away from anything that creates a magnetic field like the microwave.
Good Luck
Jim at http://www.monitorsdirect.com
Reply to GoSharks
- 0 +
Sometimes, if you have powerful speakers and they're right beside the monitor, they will cause this problem too.
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
Reply to Arrow
I bought a power-surge protector that had a EMI/RFI noise filter. That fixed it right up.
Thanks for your suggestions.
Reply to Anonymous
There are 1308 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
