wireless and WPA download speed observations
G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
Hello all,
While downloading a 1.9 Gb zipped file I disabled and re-enabled WPA
encryption a few times to see what the difference would be. Observations:
WPA-PSK / TKIP enabled: 157 Kb/s
WPA disabled: 360 Kb/s
Questions:
1. Is this a normal percentage of loss of speed due to the WPA encryption?
2. If not, what can I do to decrease the difference?
For clarity, the same 1.9 Gb file was being downloaded while I tested, I
pauzed the download before switching, resuming it after I switched.
Thanks and cheers,
Leon
G
Guest
Guest
Leon <me@this.org.net.com> wrote in
news:U34Zc.497230$6p.96321@news.easynews.com:
oops. Make that: WPA - Pre Shared Passphrase / TKIP enabled: 157 Kb/s
Leon
G
Guest
Guest
Leon <me@this.org.net.com> wrote in message news:<s94Zc.498859$y4.92157@news.easynews.com>...
So when you disable WPA, it works with no crypro at all, even WEP?
What is the speed with WEP-40 or 128?
--PA
G
Guest
Guest
pavel_a@geeklife.com (Pavel A.) wrote in
news:d3ca03a5.0409010422.10df51f8@posting.google.com:
> --PA
Yes, without encryption it works great and fast, I had 500 Kb/sec today. I
will not use WEP since that is marginally better than no encryption.
Leon
