CoD WaW automatically uses whatever speaker settings the computer is set to use (through the control panel).
Make sure your default speaker setup within windows is set to 5.1 (or 7.1, or whatever your using), and thats what the game will automatically output too. If the sound setting in game says your running stereo, thats likely what windows is set to use.
There is actually a problem with the latest patch that they released for WaW, i believe its 1.2
Anyways, when you install that there is absolutely no sound, so you have to go in and change your output settings to the lowest possible configuration =(
checked everything, windows default is set to 5.1, in the sound card control panel is set to 5.1, and the surround is fine actually, played movies, even played other games with it, latest Dead Space, everything is fine
even tried to force 5.1 in the config file of W@W, it goes back to stereo sound.
guess im gon have to wait for the 1.3 patch
thanx for ur input guys, much appreciated peace
You don't have to wait to get sound working on COD:5, you just have to lower your sound settings.
Right click on the little speaker icon, and go to playback devices (this is if you have vista, I'm pretty sure XP doesn't have this problem).
Right click the speakers you are using, and go to properties.
Click the advanced tab.
Then, you have to select the 16bit, 44100 Hz (CD quality) setting. That should make sound work until 1.3 comes out (sometime this month i believe.
It's annoying >.< but better than having no sound at all.
^^everything is double checked and set to surround
its just in the game the option to set output type is greyd out and is set to stereo, cant change that
I have the same problem. All is set correctly in Vista, and I get surround sound in other apps.
Hi,I have a somewhat different problem.
The sound works great but if i die the sound dissapears.
I don't know what to do,I searched for fixes but they don't work.
I have XP with SP3 and have the 1.4 patch for my CoD:World at War
Thank you for your time.
Hi, I had this problem too. Running Vista Ultimate x64, with X-Fi Fatal1ty PCI-E. I had my speakers set to quadraphonic, since that is what I actually have. Works fine for every other app, except CoD:WaW.
Searched for a way to get it to work in Alchemy, no go.
Found this forum.
Lowered KHz, no go.
Tried forcing the sound in the console, no go.
While playing around in the CoD console, however, I noticed there were two settings: snd_force71 and snd_force51, but there was no snd_force41. Light bulb goes on.
I go to back to the control panel and set the speakers for 5.1 sound. Have not tried this before, so I was expecting to be disappointed since I don't actually have a 5.1 setup. No separate subwoofer or center channel speaker in my possession. However, you can tell Windows which speakers you actually have, and it will compensate by downmixing. So I clear the subwoofer and center channel speakers. Quadraphonic 5.1, or 5.1 minus 1.1? Whatever. Either way, it should be exactly the same as running in quadraphonic, like I was before.
But... CoD:WaW now works with proper surround. Seems a bit silly to have 5.1 channels downmixed to four and have it work rather than just output four channels, but whatever. Silly programmers.
