System:
Cheap 300W ps macron
fic ad 11 mb
amd 1700+
wd 40g 7200 hd
diamond 550 viper
Phillips 8x burner
dell 12x dvd
powerup 128MB ddr
xp upgrade
Sorry i've got to do this in steps cause it reboots all the time.
Ok sometimes it will run for hours if you leave it alone. Like it ran long enough to install 98 and xp no problem. It also ran all night crunching a movie to divx, no problem.
Other stuff will make it reboot everytime. WCPUID causes a reboot every time. It has rebboted during surfing, exploring and once even during a boot before I could get a password in. It just killed IE completely without a trace but the system kept running Sometimes it will blue screen but you hit anykey and everything looks fine and it doesn't stop what it was doing.
I've run cpu and memory stress tests and sometime they run fine and other times the system will reboot after a few minutes. It almost never locks up in the usual way where you loose functionality. It either reboots, flashes a blue screen and keeps working fine, or kill the app you are in (IE, explorer, ect) but the system stays up.
Give me fuel, give me fire, give me that which I desire.<P ID="edit"><FONT SIZE=-1><EM>Edited by lakedude on 05/10/02 06:45 PM.</EM></FONT></P>
Two things get my attention here right away .. cheapo PSU gotta go ! and get some name brand memory and like 128mb more that you have
lagger
<b><font color=blue>Checking under my North<font color=red> AND</font color=red> South bridges for <font color=green>Trolls</font color=green></font color=blue>
I don't like your PSU, there is a great chance that your PSU is the problem.
But also check if your RAM timings are normal.
With a hovering case crashing takes a whole new meaning...
hey man!
what are ur voltages like???
Motherboard monitor them to us!
Today on Toms: Trisexual hamsters, anal applications of peanut butter and Marrige councilling!
It really doesnt sound too power supply or ram related since the installs went off with out a hitch. I have had to underclock a buddies axp once cause it would run stable try that. Or a new heatsink fan combo.
But heres my advice lose the vid card I used to have a S3 card and their drivers were [-peep-] for 98 let alone XP.
-Jeremy
<font color=blue>Just some advice from your friendly neighborhood blue man </font color=blue>
I have nothing to add. I'd install motherboard monitor and check your voltages and temps. Make sure everything is cool in your device manager. Try updating all the drivers.
Is it unstable with nothing but the OS and basic programs on the drive, or do you have a questionable piece of software installed?
<font color=red>I have a computer and it does weird stuff. please help.</font color=red>
Ok here goes:
Got fed up cause the system would not stay stable long enough to even post a darn help thread. The only thing I could do that was free was kill xp and go back to 98se. I loaded 98se, via mobo drivers w sound, video drivers (it is a tnt card BTW), temp, voltage and fan monitor software, and then tried to install the nic and at that point all I got was a black screen. The cards do not seat well because of the crappy case design so I nixed the nic. I'm running 98se and no nic and it is pretty stable but not perfect. It still has problems every hour or two sometimes but has been crunching a mpeg for hours now with no problem. It seems to have the most trouble when opening a new app or closing an old one. It doesn't reboot anymore. Now when it locks up it freezes more like I'm used to. I don't know if XP or that nic card was the problem but it is running good enough for now. Thanks everybody.
BTW the only weird thing the temp/fan/voltage shows is that the 5v is a little low at around 4.8v. None of the monitors ever have anything to report when a failure occurs.
During the install the cd burner software locked up right at the end of the install and Zoran soft dvd locked it up every time so I was still worried until today. The Zoran does not work on any machine. The system has been up and running at 100% cpu load most of the work day today. I'm 95% into a 7.5 hour job and still going strong. I have not tried to burn a cd yet but I think the system is ok. Thanks again.
looks like u got the cure of the crap components my friend *i pity you*
Dude its very much you video card I'm almost 100% sure.
-Jeremy
Dude I'm pretty sure that it is not the video card cause it is a very old and well tested card. It came out of a system that was 100% reliable. Is there a compatability issue? I guess it wouldn't kill me to swap cards with another system. I've got a rage 2c that I could put in.
Update:
The system is very strange. I have run several mpeg conversions using Fair Use with no problems what so ever. Fair Use is known to be hard on a system and sometimes and oc'ed system will work fine on everything except Fair Use. On my system it works perfect. Fair Use will run huge files at 100% cpu load for 8 to 12 hours no problem.
When surfing sometimes I'll get an invalad page, internal error, or illegal operation error. When you click ok on the error ALL copies of IE go away. Usually the system stays up. Sometimes if you are in the middle of a download you can move the error box to one side and the download will complete fine. Since I switched to 98se/no nic it has only rebooted for no reason one time. It was popping off every few minutes in xp/nic. Sometimes it will pop up an error offline when using explorer to view pics. Once something is running it seems fine until something new happens. A new instance of explorer or ie will sometimes cause the problem. I almost alway happens when you are clicking on something. Click=error. Very strange.
corrupted windows/explorer/internet explorer possibly.
not having modem IRQ problems are you?
First check for any IRQ problems, also check if your DMA in enabled (if not that may point towards IRQ problems).
Which soundcard are you using?
Sound is built in to mb.
From experience:
1) FIC is crapola.
2) Random reboots and random install errors (especially Win2K failing to copy some file) are usually memory errors.
3) Lockups are usually heat problems or power supply problems. Power supply problems often also cause the system to take a few seconds to start POSTing.
I'd first try running memtest86. If it fails memtest86, go get yourself some different memory, preferably Crucial or Corsair.
If memtest86 passes, I'd see about logging voltage levels over time and see if they remain steady. If they're low (i.e. 5V is below 4.85) or they deviate beyond 0.05V, your power supply's not cutting it.
<pre>We now <b>return</b>(<font color=blue>-1</font color=blue> ) to an irregular program scheduler.</pre><p>
I'm not at home so I can't do anything to the system right now. I have kept an eye on voltages and the 5v seems to be a little irregular. At bootup it starts out at around 5 and drops over time and sometimes does get around 4.8vdc. I will either swap vid cards or ps tonight with older machine.
UPDATE
ARRRGGGGGG!!!!! This thing is gonna get me drinkin heavy again.
OK last night I was on line to tell you that with no changes since last time that the system has been runing perfect. I did another movie and even burned cd-r and everything was fine.........until I tried to post the good news last night and poof. Black screen with green bars every quarter inch or so at the top. Now I'm startin to think it is the vid card because the only other time I have ever seen a screen like that before was when I was trying to figure out which vid-card Linux needed to think my system had. Linux did not like the setting for the correct card and gave me a very similar looking screen. I had to play with Linux and use standard vga drivers to get the system to work.
I'd suggest you get that P/S changed pronto. It sounds like the power supply is lagging, and if you run a system without sufficient power, it's actually rather wearing on the components. I lost a perfectly good 440LX motherboard that way...
Kell,
The power supply would have [-peep-] out in the install what makes you think it would go now? I have had these cards in my shop and I used to be a hardcore S3 man so I had one in my box. S3 stopped makeing drivers when talks of the merger with VIA started. I saw the same symptoms time and time again on my customers and my own system. But hey you never know that power supply might be going but I doubt it since its a rule of thumb with power supplies, they usually die early if they die at all.
-Jeremy
| Quote : The power supply would have [-peep-] out in the install what makes you think it would go now? |
Experience.
The power supply doesn't have to be failing to cause problems, it could simply be insufficient.
Last time I had to deal with an insufficient power supply, it was when I added my RAID adapter (full-length PCI unit with four SIMMs and a half-length daughtercard). Of course, I stupidly didn't install drivers beforehand, and I had to reinstall WinNT to get the boot-time drivers in place. The install went off without a hitch, but odd problems and lockups occurred after the install--not to mention which, the system took longer and longer to start POSTing every time I reset it.
The power supply ended up dead. So did the motherboard. The PS never showed a problem until I put in one more power-hungry component.
You still say that the videocard is the problem?
Weird because it is a good card... based on the Nvidia Nrivia TNT... Diamond was a good brand when those cards came out.
Finally posting from home.
Update temps and voltages:
12v=12.4
5v=4.85
3.3v=3.29
core=1.776
cputemp=118F
system=104F
are those values under full load?
if so... well done!
Whats better, <font color=blue>Intel</font color=blue> or <font color=green>AMD?</font color=green>
They look fine.
"are those values under full load?" Yep 100% cpu load.
I don't trust the numbers. The same software also measures fan speed and I tested it by jabbing a pen into the fan to stop it and the rpms shown by the software did not change.
BTW it ran perfect again last night but the night before it was really bad (locking up rebooting)like it was with xp on it. Last night I was on line clicking many things having multiple copies of IE open and typing and it worked perfect for hours. How am I gonna know if it is fixed if it will work fine for days??
Give me fuel, give me fire, give me that which I desire.<P ID="edit"><FONT SIZE=-1><EM>Edited by lakedude on 05/24/02 04:51 PM.</EM></FONT></P>
| Quote : I don't trust the numbers. The same software also measures fan speed and I tested it by jabbing a pen into the fan to stop it and the rpms shown by the software did not change. |
About how long did you keep the fan stopped?
Most health monitor software has to make regular polls of the sensor chips every few seconds (usually about 4 seconds). If you stop the fan for ten seconds and it does nothing to sensor readings, you can be fairly certain the sensors aren't working.
As for the voltage, consider me spoiled, but 4.85 is low for a 5V line, even for something under full load. My voltage rails barely flex at all between idle and full load. You might check and see if the power supply contains any adjustable potentiometors, but that's really just a hack type solution.
As far as the vidcard quality, I had a Viper V550 years ago. It worked great, with both Diamond's drivers and the nVidia reference drivers. I sold it to a co-worker shortly after I got my GeForce.
Ok I got it figured out. I was thinking that the PS fan was the chassis fan. There is a plug where you could put an extra chassis fan but it is used for the north bridge fan. The PS fan is not monitored. Stopping the cpu fan shows up as a stoppage under the cpu fan monitor (of course) and stopping the north bridge fan shows up under the chassis fan monitor. I guess the software works after all.
Well my 5V line is 4.82V now... whit only IE and Winamp open. But I have an Enermax 350W PSU... with not that many components connected to it.
More updates:
I just finished 2 movies back to back that were running at 100% cpu load for 20 hours with no problems until I got online and started posting. I only have problems when clicking or typing. Very strange. Since I started typing it has killed IE once and blacked out requiring a reboot once.
I had something similair about a half year ago.
It resulted to be some IRQ sharing problems, while Windows wasn't showing any IRQ errors. After I disabled the onboard COM ports (I don't use them) the problem was solved.
Another thing you can try is downloading the Via Latency Patch here: <A HREF="http://www.networking.tzo.com/net/software/" target="_new">http://www.networking.tzo.com/net/software/</A>.
Hey Lakedude,
I had this exact same error when the system would restart for no reason, or freeze and leave a black screen with little green lines. It also happened with a cheap 300Watt power supply. The weird thing was it would do it at odd times, sometimes I'd just leave my system on and walk away from it and come back to a black screen. other times it would occur when playing games. It was really random. I replaced the PSU with a high quality 350W Antec PSU and never had another problem. Also for the power requirements of your system you really should use atleast a 350W PSU.
I'm gonna try svol's ideas first cause they are free. I have a better quality PS from an older system but is actually rated lower then the newer cheeper one. My problem is similar except that if I walk away the system always stays up even with ball buster apps running. It only dies when I'm clicking or typing or an app is starting a new window or closing one. Once something is running it will keep going fine forever it seems. Still if it is hardware I suspect the PS first.
Ok com1, com2, and lpt are all red x'ed. Disabled in hardware profile. No problem so far but it is too soon to tell. Got fingers crossed. Burning a CD and posting and downloading at the same time right now.
I hope it works.
UPDATE
Its dead.
I was doing a conversion again last night and woke up to "unable to write to drive D". The drive is partitioned and upon reboot both partitions are gone. Bios does not even pick up a drive at all. Not sure if this is the same problem as before or a new one. Gonna go downstairs and see if I can't get it running again.
Its alive again.
Don't know if it was the powerdown or new hd cable but we are up again.
While we're on the subject of HD cables, I'll point out that the 80-conductor IDE cables need to be treated with care. They don't like being folded, stacked, creased, or crumpled; such treatment will affect performance and could possibly also affect stability.
Delicate crap like that is partly why I tend to be an all-SCSI man.
Uh oh, I rounded my 80-conducor cables by folding and crumpling them... I don't have any problems as far as I know, strange.
<b>P75 @ 90 Mhz</b>... because I need the speed.
It shouldn't bother your P75 even if one came half-way off.
<font color=green><b>Inside every older person is a younger person wondering what the hell happened!
did P75's even have IDE cables? LOL
<font color=green>Hamsters</font color=green> <font color=red>don't</font color=red> <font color=green>play</font color=green> <font color=red>Soccer.</font color=red>
You really think I'm that mad that I use 80-conductor cables with my P75?
For your information my P75 has IDE cables with some kind of PIO DMA I think
my p-166 came with a LBA mode seagate 2gig.
Well my P75+mobo came with nothing (somebody gave it to me after he upgraded his PC), but my dad gave me 80MB RAM from his work and we where alowed to keep an old Work PC (486 Compaq) when they changed it with a P166, I already bought a HD (Seagate 6 GB), but that one is now in my own rig and I moved the 2GB Quantum HD from the Compaq 486 to the P75 server. I also bought a cheap videocard and a AT minitower. The CDROM, FDs, cables, etc. where already laying around so it was a cheap server.
I don't think you are mad at all. Everyone I know has 36 fans in their case.
Nah, not 36 but you know that.
But for fun I will count all the PC fans in the house:
14 In my rig
2 In my server
1 In my dad's 'work' PC
2 In my brothers PC
19 fans total...wow that our house still stands on the ground.
Ok. You win. You have the windiest family I have ever heard of.
<b><font color=blue>The shortest distance between two points is under construction.
hmmmm fans
got me thinking
hows this for a potential casemod. on a midtower case
1cpu fan 80mm
northbridge 40mm fan
gpu socket 370 cooler with 50mm fan
2 40mm coling fans for ramsinks
3 PCI slot coolers
2 rear casefans
2 psu fans (dunno if they count)
4 80mm front bottom casefans
2 80mm casefans in 2 spare 5.25" drive slots
1 3.5" slot drive cooler
3 120mm top casefans
4 or possibly 5 120mm casefans for left case panel
2 for right pannel
elivate the case for 2 or 3 120mm fans underneath
that would give a grand total of approx 30 fans.
a good idea no?
Sure. Great idea.
<pre>I would hate to pay for your power bill.</pre><p>
Hmmm...
-- Fans I have running --
15 fans in the rig.
5 fans in the firewall
6 fans in the headless server
2 fans in the father's PC
5 fans in the mother's PC
(total 33 fans running)
-- Fans which are not running --
5 fans in the headless slave server, which will soon be online
5 fans in this 5u chassis i've got, if i could just find something to do with it
3 fans in my old RAID cabinet, which I can't seem to get any worthy buyers on =/
(total 13 fans not running)
There are 2256 identified and unidentified users. To see the list of identified users, Click here.
