A7N8X-Del ... Lan problem
I have just built my first system from scratch and everything went well except that I have not been able to conect to the internet(ADSL) through either of the built in lan ports.
MB - A7N8X Deluxe
OS - Windows XP
Also is there an easy way to remove/delete Windows XP, as I would like to try the install from scratch again, I tried to reformat the drive, but, XP will not cooperate.
Thanks .... BFB
Plan ahead, it wasn't raining when Noah built the ark!
4 answers Last reply
More about a7n8x problem
  1. First things first...
    To reinstall Windows XP... you just need to boot from the CD Rom again...like you did before...delete the old partition...and go from there...
    Shouldn't be a problem...if your trying to remove XP from within XP, that won't work...
    Okay...now...here's the funny part about the LAN ports on any Nforce 2 board...
    They won't work until you install the Nvidia Nforce2 Driver set..see link below..
    <A HREF="http://www.nvidia.com/view.asp?IO=nforce_udp_winxp_2.03" target="_new">http://www.nvidia.com/view.asp?IO=nforce_udp_winxp_2.03</A>
    So..basically what you have to do is install XP..and then imediately thereafter...install the Nvidia motherboard drivers...
    I've found the easiest way to do this...is to just burn them to a disk before installation..and then copying them over..
    Or..you can create a second partition on your hard drive...and just store them there...
    Hope this helps..
    Aliu
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    -Albert Einstein
    3DMark2001<A HREF="http://service.futuremark.com/compare?2k1=6317063" target="_new">http://service.futuremark.com/compare?2k1=6317063</A>
  2. Thank for the help, just one last question, are the Nvidia Nforce2 Drivers that come on the cd with the MB no good?
    BFB
  3. install XP
    XPSP1
    Chipset drivers
    all other hardware
    Reboot everytime system wants. Do not stack reboots.
  4. Final resolution of problem.
    Had to run ipconfig /release
    followed by ipconfig /reset
    Turns out the drivers supplied with the MB do work.
    Thanks for all the suggestions....BFB
Motherboards LAN Windows XP
