Hello. I am having a weird computer problem and don’t know what to do. I recently put together a computer with a Biostar M7VIG Pro motherboard, AMD Athlon XP 2000+, 256MB of PC2100 RAM, 8GB Hard drive, a floppy drive and CDRW. After getting it together, I installed Windows XP and it worked with no problems for about a month. Then one day, it shut off and appeared to be rebooting, but nothing ever came up on the screen. After that, it would not power on at all. And I don’t mean that it wouldn’t boot. You press the power button on the front, and NOTHING happens, no fans, no lights, nothing.
I first thought it was the power supply, so I tried a different power supply. Still nothing. I then tested the Power Supply that I thought was broken on another computer, and it worked.
Ok, so it’s not the power supply. What else could it be? I figure it HAS to be the motherboard. If something were wrong with the processor or memory, the computer would turn on but just not do anything. The motherboard signals for the power supply to activate when the front power switch is pressed, and it isn’t doing that.
So, I think I’ve narrowed it down, so I prepare the motherboard for RMA. I got it at Directron.com, so I go through the whole process. I finally got a package from them the other day. But, it is the same motherboard! Written on the RMA slip says “TESTED GOOD”. I then installed the motherboard in a new case, with a new power supply. I checked and double checked all connections, and STILL NOTHING!
I just called Directron to see how they tested it. I didn’t know if they just plug in some sort of testing device, but they claim that they actually plug in a processor and memory, and run diagnostics.
So somehow this motherboard tested good for them, but I cannot get it to work at all. Can anyone offer any suggestions? Maybe there is just something I don’t realize or don’t know.
Thanks,
Joe
Thanks,
Joe
