Folder Options Problem
Forum Windows XP : Windows XP General Discussion - Folder Options Problem
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
- I created a folder icon on the desktop.
- right click on the icon, i see Search..., explorer, and open, where
search is selected (bold).
- when I left click to open the folder, the search companion view comes
up, instead of opening in the explorer view.
- I have gone to explorer\tools\folder options\file types\ none\folder
and selected explorer as the default, but that doesn't help.
- I think something in the registry is incorrectly set, and override
the folder options setting.
- I'm also not sure how this happenned, unless it was done via a MS
update install.
Can anyone help me????
ejaggers
Sponsored Links
Fixes the problem where Search or Command Prompt opens
when double clicking a folder © Doug Knox
http://www.dougknox.com/xp/scripts [...] r_open.htm
Search Companion Starts If You Double-Click a Folder
http://support.microsoft.com/?kbid=321186
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:ejaggers.1kiqdm@pcbanter.net,
ejaggers <ejaggers.1kiqdm@pcbanter.net> hunted and pecked:
> comes up, instead of opening in the explorer view.
> update install.
> ejaggers
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Folder Options Problem
There are 561 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
