help on overclocking P4
Forum Motherboards & Memory : General Motherboard - help on overclocking P4
hi guys .. wonder if anyone will be kind enuff to teach mi how to overclock my p4 on a intel mobo. i tried to go in to the bios .. but it does not allow me to tweak my FSB.....
thanks alot !!!!!!!!
Sponsored Links
What P4 do you have?
<font color=blue>Watts mean squat if you don't have quality!</font color=blue>
Reply to Crashman
Also, which Intel Mobo?
Reply to Prof133
I'm using a P4 2.0GA and my mobo is d845GEBV2.
Reply to applezoo
Yeah, the said motherboard doesn't allow changes in FSB frequency - as you have observed. So, sadly it is not possible to overclock.
Reply to Prof133
Oh..... so as to say i can't overclock at all ?
any other ways ?
and lastly can anyone suggest a clockable mobo for my P4?
Reply to applezoo
Quote :
any other ways ?
If the mobo doesn't allow FSB changes there is no way to overclock a P4.
Quote :
How much do you want to spend? List your computer's specs. Escecially, the memory.
Reply to Prof133
hmm.... i'm currently using 1 x 256MB and 1 x 512 MB kingston 266Mhz DDRam.
abt the buget ... i'm using the singapore currency ... so
i will settle with anything that is within $150-200.
But if the mobo is really gd ... i dun mind spending abit more :)
thanx alot !!!!!
Reply to applezoo
OK, I'm going to assume that means it's a P4 2.0 with 512k cache (aka, the Northwood core). Now, we know your board supports 133MHz bus clock (aka 533MHz FSB). So you CAN try overclocking it to 2666MHz on your board buy raising the bus speed ON THE CPU from 100MHz (400) to 133MHz (533). If you have an address for me to send "Crashman's Hardware Overclocking Guide", PM me and I'll send it to you. This type of overclocking requires the minipulation of pins.
Reply to Crashman
It is possible, because he has a 400 bus CPU. All he needs to do is break off pin BSEL0 from the CPU to make the motherboard detect it as a P4 2.66/533. Also, shorting pins VID3 to VSS will raise his core voltage from 1.50v to 1.70v.
Reply to Crashman
Hey, here's some news for you: I'm thinking of writing an article on adding a 8-switch microswitch to one of these boards so you can do those settings and reverse them easily on any Intel board with many 400-bus processors. If you wanted to send me a board I'd do the mods for free. This could be my chance to break into journalism.
Reply to Crashman
Well, now that is some valuable information. I say: go for it.:D
Reply to Prof133
I suggest that anyone who wants to attempt CPU modification varify that CPU's ability to run at the higher bus speed first (on a board that allows overclocking) As for modifying the board to use DIP switches instead of CPU bus speed/vcore detection pins, well at least you can set the CPU back to stock.
Reply to Crashman
haha .. it will be great if u r 2 do it 4 free ... but i cann't live without my comp running !!!! Think of getting another board to save all the trouble.Any boards to reccomend for my P4 2.0AGhz?
Reply to applezoo
Abit BH7 is gaining praise as an excellent overclocking board. Cost under $100.
Reply to Prof133
Thanx for the info .... btw .. ur $100+ is in wat currency ?
Any other choices ???
Reply to applezoo
- US dollars.
- I can't think of any other motherboards in that class and price range that would cause me to look past BH7.
Reply to Prof133
Looks like if i want to overclock i have to open up my casing and do the job.I'm very much interested in the guide.Pls mail it to me.
My e-mail is midnightblues79@hotmail.com
Thanx alot !!!
Reply to applezoo
Your mail has been sent, you should remove your address from your last post to prevent spammers from using it.
Reply to Crashman
Thanx alot. I receive it the mail.But i think i will not overclock it now as i will have nothing to fall back on if I fail! Think i will experiment it when i get another mobo.
Other than the mobo from abit,is there any other good and stable mobo?
Reply to applezoo
Right. It would be reversable of course if you modified the board to turn that socket pin on and off with a switch.
Right now the fastest boards have the Intel 875P chipset which was introduced about a week ago. These use Dual Channel DDR and new memory tricks to make the thing far faster than previous boards. Abit even advertises that theirs will always be stable to at least "1 gigahertz bus speed", which is 250MHz, aka QDR1000. Compared to your QDR400 bus of course, it's 250% higher.
Reply to Crashman
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > help on overclocking P4
There are 1193 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
