Hi guys and girls... ive just built my new system and im loving it... i havent been playing any games on a pc system for like ages.. and i was just wondering if ut was possible to play crysis on the spec the i have built? spec is in sig btw. and if i can what would u say the optimal settings would be..
thanks in advance for ur input
Louis
------------------------------Antec 900, Asus P5Q SE/R,E8400 CPU, Antec 650W PSU, OCZ 4GIG DDR2 800, WD VelociRaptor 150GB, HIS Radeon HD 4850 IceQ 4, LG DVD/DL RW, LG 32Inch LCD
Vista Biz 64bit
Vista Biz 64bit
Reply to LouisM
Vista Biz 64bit
Reply to LouisM
Your system spec is similar to mine, except you have 4Gb of memory over my 2Gb, and a 32in Screen. On my 20in Samsung TFT my rig runs Crysis smooth on high settings at 1440x900, its playable at 1650x1050 but not as smooth.
thanks for that tobensg.. ill give it a try on those specs and report back..
sweet
Vista Biz 64bit
Reply to LouisM
