Now i have a realy mesy problem whith my CoD4 profile...the thing is that i have 4 of them and thay all work fine exept for one of them....my first is in lvl 55 whith lot's of kill's and lot's of acheavments that i have worked on realy hurd,but then i got board and made 3 more,and so i started from 0 and i got to lvl 38 and then i hade this problem that whean i whanted to join a game it stoped working and this showed up..iw3mp.exe hase stopped working.....and it only hapens to the 2 profile lvl38 and to no uther,,,now i have reconsidered to reinsrall CoD4 but that whude mean that all the profiles whude b lost and and the probleme two.
Please help me am realy REALY pisses off and desperet for HELLP!!!!!!!
"I had the same error and it was due to audio issues. I switched from a USB mic to an Analog one.
Go to Start then Control Panel
Double click on the Sound Tool
Click on the Recording tab
Right click and select "View Disabled Devices"
Enable the Stereo Mix
If all else fails try connecting something to the microphone jack on your sound card. A microphone is optimal but using a pair of headphones or even just a phono plug adapter will work. Do not plug anything that is powered into your microphone jack as it could cause damage to your system."
also if your using vista, cod dowsnt like some playback quality options, 24 bit only up to 4800hz anything above and most the time it wont run (sometimes does, then kaput)
