Archived from groups: alt.internet.wireless (
More info?)
On Sun, 5 Sep 2004 09:44:30 -0600, "Quaoar" <quaoar@tenthplanet.net>
wrote:
>"Richard Buttrey" <chaos.theory.nospam.removethis@zen.co.uk> wrote in
>message news
![:p :p]()
gfhj0l1f84q36340gm2l4gmukjibpbvbh@4ax.com...
>>I have a Netgear wireless router and have just bought a Linksys WPS11
>> wireless print server for connecting to my HP Laserjet 4 printer.
>> My problem is that I am unable to get the wireless settings to 'stick'
>> The WPS11 comes with a sofware set up program called Bi-Admin.
>> The sequence of events is as follows.
>> 1. Hardwire WPS11 to Netgear router with ethernet cable, and connect
>> to printer with standard parallel printer cable.
>> 2. Power up WPS11 setting it to the default factory settings.
>> 3. Run Bi-Admin program which succesfully detects the WPS11 - as
>> indeed does the Netgear router admin software.
>> 4. At this stage I can ping the WPS11 and print a test print from
>> Bi-Admin
>> 5. With Bi-admin, configure the WPS11 with the fixed IP address
>> indicated by the test print - (and also the Netgear admin attached
>> device list). Save this setting to the WPS11
>> 6. Confirm step 4 still works.
>> 7. Recycle the power on the WPS11 and confirm step 4 again.
>> 8 With Bi-admin, change the SSID from the default setting to the SSID
>> name of the Netgear router. Save this to the WPS11
>> It's at this stage that everything goes wrong. I can still ping the
>> WPS11, but as soon as I try a test print from Bi-Admin, Bi-Admin
>> 'loses' its connection to the WPS11. This happens both with the
>> hardwire still in place, and also when I've powercycled the WPS11 and
>> removed the hardwire.
>> There does not appear to be any physical fault with the WPS11 and all
>> the LEDs light up when they should. The wireless WAN led light also
>> blinks suggesting that it's polling for a wireless signal.
>> I've spent the last four Friday afternoons trying to get this to work
>> and even had it replaced by Linksys, all to no avail.
>> Has anyone had any experience with setting this thing up and can offer
>> advice.
>> Rgds,
>> __
>> Richard Buttrey
>> Grappenhall, Cheshire, UK
>> __________________________
>I would first confirm that the router will accept a static IP address
>from its reserved block of DHCP addresses. You should be able to set
>the IP address to one of your choosing outside the reserved DHCP range.
>That is, if the router has a reserved DHCP range. Second, broadcast the
>SSID. If this server is designed anything like other Linksys specialty
>wireless adapters, the server will have difficulty if the SSID is not
>broadcast. You might also, when the setup is complete and the ethernet
>is disconnected, power cycle both the router and server and see if they
>can then negotiate. Lastly, restart Bi-Admin and let it find the
>wireless server in a new session.
>Q
Many thanks for these suggestions.
Just a small point, what exactly do you mean by 'broadcast the SSID'?
Something else to try this coming Friday afternoon.
I'll let you know
Rgds
__
Richard Buttrey
