Tom's Hardware > Forum > Games General > PC Gaming > CNC3 Tiberium Wars problem with ATI Radeon 9600 256mb
Forum Games General : PC Gaming - CNC3 Tiberium Wars problem with ATI Radeon 9600 256mb
I am having problems running cnc3.
I have met all the minimum requirements yet errors occur when a highly detailed scenery (example: Nod nuke explodes.) occurs. Also ive set all settings to low even the resolution to 800x600 yet there are some false-color images and glitches occur in some terrain and structures. I really need help!
My Specs:
Pentium(R) 4 3.20 ghz
1024 gb of RAM
ATI Radeon 9600/X1050 series 256mb
Windows XP Professional
Sponsored Links
Chances are your graphics card or CPU is overheating. Use a program like GPU-Z to keep track of your GPU temp, and RealTemp or CoreTemp to keep track of your CPU temp.
You might have to de-dust fans/heatsinks or improve airflow.
Also, minimum requirements on games are the setups that are required to run the game at absolute minimum settings, and even then it's not a 60-fps guarantee.
------------------------------ Antec 1200 -=- Corsair HX1000 -=- GA-X48-DQ6 -=- Q6600 @ 3.2 GHz -=- 8GB RAM @ 800 MHz CL4 -=- 4870X2 800/1000 -=- 2x 500GB 7.2k RPM -=- 150GB 10k RPM
Reply to Kraynor
- 0 +
Hey buddy i have CNC3 to and have same graphic card as you and still i have no problems with it... i think it could be over heating that's the only answer i can think of..
My specs....
Pentium(R) 4 3.00 ghz
1024 gb of RAM
Reply to mihcael
I have met all the minimum requirements yet errors occur when a highly detailed scenery ...
Did you find a resolution to this problem?
I have a related ATI 9600 video card issue as well.
ASUS A7N8X-X
AMD Athlon XP 3200
2.2GHz
2.5g DDR RAM
AGP Video
700w Thermaltake PSU
Windows XP Pro
Build 5.1 2608 SP3
Message edited by edward64 on 06-06-2009 at 07:27:36 AM
Reply to edward64
i get these glitches in all games, either when i turn AA on too high, or when my card is OC'ed too much and overheating.
------------------------------ Core I7 920 @ 3.66ghz | Xfx 4870 1gb Tri-Fire | DFI Lanparty x58 UT | G.Skill Trident 3x2gb @1834mhz | Asus Xonar Dx | Coolermaster Ultimate 1100w | Coolermaster Storm Sniper case | BenQ E2400HD 24inch 1920x1080 | Thermalright TRUE Push/Pull Fan |
Reply to stevensl2
There are 1057 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
