I just finished building my Canterwood system and thought I would post regarding the one bug I have found.
I am running two Cuda V's in a RAID 0 using the IAA integrated RAID. I was having a bear of a time getting XP installed, and after about five tries, I finally figured out the problem and the workaround.
In the Award BIOS, it's necessary to select the Boot order of SCSI/RAID devices. Since there are three different RAID controllers on 8KNXP (two SATA and one PATA) I had to put the Intel RAID drivers first on the pecking order. Then, of course, I had to select "SCSI" as one of my "Boot" devices.
Initially, everything was fine. I hit CTRL-I during Intel's RAID setup to create the RAID volume, then hit F6 during XP's initial startup to load Intel's RAID drivers for Windows. Windows took the drivers without issue, I partitioned the array, and installation began. The problems started after the initial reboot.
Apparently, a soft-reboot of the 8KNXP causes the BIOS to "lose" the SCSI/RAID information. It took me a few tries to figure out that it was specifically the BIOS that was the problem, and not the RAID drivers. I did learn that if I turn the computer all the way off, rather than hitting reset or doing a reboot, the BIOS will correctly load the RAID device on the next power-up.
So, the short of it is: I cannot "restart" Windows. I have to actually "turn off" windows and then power back up in order for the BIOS to load the Intel RAID device so that XP knows to load the IAA drivers. Otherwise, the system will hang on boot-up.
I just thought I'd post this in case anyone else buys this motherboard. Other than that little annoyance, it is a great motherboard, and everything else came off without a hitch. The performance is terrific, and the board has a lot of great features. It is kind of a pain remembering to stop a software installation from automatically rebooting the system. Hopefully, Gigabyte will release a fix for this soon. These are the drawbacks to early adoption.
<font color=green>The Netherlands is where you go when you're too good for heaven.</font color=green> :tongue:
