Archived from groups: alt.internet.wireless (More info?)
Most of the hi-gain antenna I've seen are for the router side of a
wireless network. Does anyone make one for the wireless network card
itself?
: Most of the hi-gain antenna I've seen are for the router side of a
: wireless network. Does anyone make one for the wireless network card
: itself?
Sure ;-)
Link below.
m.
milea wireless communications, http://milea.pl
WLAN-FAQ: http://milea.pl/pl/wlan-faq/
main() {int j=-1;char t[]="eYadlg2eYj[af8ead]Y&hd\n";while(t[j]!='\n') { putchar(t[++j]+'\10');} return 0;}
>itself?
Yes. However, your unspecified wireless network card must have some
type of RF connector. This is one reason that the Senao and
Orinoco(Proxim) cards are so popular. The usual way is to attach a
short pigail between the card and the antenna. Then, you can use any
antenna that has an RF connector.
If you don't have an RF connector on your wireless card, I suggest you
either butcher your card to add an RF connector or purchase a suitable
card.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
I have a DLink which does not have an RF connector. I'll have to
invest in a suitable card. I'll look at the names you provided and
thanks for the info!
> card.
Did you give up on the Mini-USB?
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
After re-reading my post, I left off a big fact. I need this for a
PCMCIA card for my laptop. Not for a wireless network card for a
desktop. Do you know if anyone makes a PCMCIA card for a laptop that
has RF connectors?
After re-reading my original post, I discovered that I left off an
important part. I need this antennae for a laptop PCMCIA card. Any
one make a PCMCIA card with RF connectors?
> has RF connectors?
The Orinoco "used to". Now you have to be careful to get one that does.
It is simple enough to buy a USB-wireless adapter. This allows the
antenna/device to be located to a more optimum position.
Some of them have built-in antennas that either readily accept antennas, or
can be modified to connect antennas.
http://www.nodomainname.co.uk/cantenna/cantenna.htm
Or a mini-USB can be mounted to a reflector, or put into a can.
http://www.dlink.com/products/?pid=175
http://www.usbwifi.orcon.net.nz/
http://makeashorterlink.com/?Q105513C8
If you're going to replace the card, also look into USB radios as a
possible option.
Also, since you seem unwilling to supply numbers, be sure to check if
your laptop uses a 16bit PCMCIA slot, or a 32bit CardBus slot. In
general, 802.11g cards are 32bit, while older 802.11b cards can be
either.
How to add a pigtail and connector to what may be your Dlink card if
you had bothered to specify the make and model (it's hard to be
subtle):
http://c0rtex.com/~will/antenna/
Senao (high power):
http://www.seattlewireless.net/index.cgi/SenaoCard
Lots of vendors and prices to choose from.
Orinoco (Proxim/Avaya/Agere/Wavelan/Lucent):
http://www.proxim.com/products/wifi/client/
Watch out for the cost of the pigtail as they can almost half the
price of the card.
http://www.fab-corp.com/K1.htm
On Wed, 8 Sep 2004 23:45:21 +0000 (UTC), dold@XReXXWirel.usenet.us.com
>> card.
I never give up. I still have one DWL-122 radio.
http://members.cruzio.com/~jeffl/p [...] s/DWL-122/
I removed the PIFA antenna, attached an SMA connector, and made some
bench tests for sensitivity, power out, and such. Then, one of my
signal generators blew up and everything is stalled while I try to fix
it.
Remind me. What was I suppose to be working on with it? I found some
sketches of a patch antenna where I planned to attach the radio.
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:3bu0k0dmq03utbu8t5dcq2oo76d6i7m8pp@4ax.com...
>>> card.
> it.
As I recall, you were going to see about the gain from putting on an
external antenna on the DWL-122.
Bob Alston
bobalston9 AT aol DOT com
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.754 / Virus Database: 504 - Release Date: 9/6/2004
We were talking about a USB radio and antenna similar to
http://www.geocities.com/lincomati [...] tenna.html
or Trevor's biquad.
you're right, dude, I didn't supply numbers but not because I was
unwilling. I have a DLINK card and I was almost positive that I
couldn't hook an external antenna without breaking in to the card
itself which is something I wasn't willing to do.
I was really looking for a solution with a card that was designed for
accepting an external antenna and an antenna that was professionally
made instead of the preverbial "tin foil" method.
Thanks for the links! I'll check them out.
Oops. Still didn't mention it. It is the DLINK DWL-G650.
See? That was painless. There's nothing really wrong with tearing
open a PCMCIA card and attaching a pigtail for an external antenna or
using one buried inside. The DWL-650+v2 model has an MMCX jack inside
that requires you drill a hole in the cover to connect.
http://www.jsbw.de/01010027.JPG
http://www.jsbw.de/01010028.JPG
http://www.jsbw.de/01010031.JPG
I'm not sure what's inside a DWL-G650 as I haven't ripped one apart
yet. You might get lucky and actually find a suitable connector.
news
ls8k0lesrloe1o04icvutmjatqqbtl7hg@4ax.com...
So, does all this mechanical disruption give a better result than installing
a USB device at the focus of a dish?
John
Version: 6.0.760 / Virus Database: 509 - Release Date: 10/09/2004
On Sun, 12 Sep 2004 21:57:01 +0100, "John Beeston"
In general yes. A properly designed antenna is much better than
hanging a USB card in a dish or can. The problem with a dish is that
at best, it's 50% efficient. The illumination angle of the USB radio
is almost hemispherical causing much of the radiation from the
transmitter to go in useless directions. The cans have their own
collection of problems. However, with a connector and panel (patch)
antenna, no signal is lost to overspray or reflector efficiency. All
of it goes into the antenna and in the general direction you want to
operate.
However, in the case of a PCMCIA (or cardbus) radio vs a USB radio,
there's also a question of power. Some USB radios are seriously under
powered at +12dBm while some PCMCIA cards belch up to +23dBm. No USB
radio comes close.
On the other foot, USB radios can easily be deployed where they will
do the most good for a clear RF path. A PCMCIA card, driving an
external antenna, will require a length of very lossy coax to be
optimally positioned. Therefore, all the increased power output of
the PCMCIA card can be lost in coax cable and connector losses.
Also, the aperature area of a good size dish is quite a bit larger
than a typical panel antenna. That means the dish will theoretically
have more gain (but a narrower beam width). However, if it per chance
has the same gain as a panel antenna, it's likely that the beamwidth
of the dish will be narrower than the patch.
In other words, it's not an easy comparison. I've done better with
reflector backed biquad antennas and sheet copper patch antennas than
with opertunistic reflectors and cans. However, I haven't exerted
much effort trying to make reflectors work while panels and biquads
get my full attention.
More painful than you think. :-)
No seriously, ok, ok, I pryed it open after much debate and yes, did
indeed see that funny, small connector that is apparently the MMCX
jack that showed in the pictures. I saw this and didn't know what it
was. Didn't look like anything that I could "jack" anything in to so
I dismissed it until I saw your post. So this is a jack that is a
standard connector that could be used with one of those fab-corp.com
15 dBi Parabolic Grid Directional Antennas with the right "pig tails"?
(Although I'm very familiar with almost every aspect of a computer,
I'm a newbie with the wireless hardware end of things so forgive me if
I don't use the right terminology. still learning.)
Thanks for the information!
I mean't supplying the model number of the card. Actually, I would
also like the FCCID number so I can dig through the techy details on
the FCC web pile.
Photo shopping list of common connectors to choose from:
http://www.hyperlinktech.com/web/connectors.php
Argh. I goofed. It's not an MMCX connector. It's a Hirose u-FL
conenctor. Also made by IPAX.
http://www.hirose.co.uk/productreleases/ufl.htm
http://www.hirose-connectors.com/products/U.FL_5.htm
(The USA web pile seems to be screwed up). Fab-Corp carries them (at
the bottom of their pigtail page).
Yep. The pigtail should be as short as possible and then connect to
an antenna or a fat length of LMR-400 coax. Coax cable losses at
2.4GHz are very high. The smaller the coax cable diameter, the higher
the loss per ft. The antennas usually have an N-Female connector, so
your pigtail will need to be a Hirose u-FL to N-Male.
What would be your antenna of choice make and model for a narrow band
directional function? I mentioned that I was looking at the
www.fab-corp.com parabolic dish. What do you think about these?
I've seen the panel anntena but what are "biquad" antennas? One last
thing, how do the Antenex 14.6 dBi Yagi anntenas on fab-corp compare
to the dish anntena?
Sorry for so many questions. You understand this stuff to a level
that I can only dream right now. :-)
> radio comes close.
DWL-122 USB-Mini Transmitter Output Power 16dBm (40mW)
Orinoco Classic Gold/Silver PCMCIA card Nominal Output Power 15 dBm
For particular point to point, a fixed dish installation would be better,
because of the narrow beam width, delivering better power to a point.
I've noticed that.
I suppose my biggest discrepancy is in making a distinction between a
reflector and an antenna. I consider the reflector to be part of an
antenna assembly. There is a feed element, and a reflector. I don't see
any radio difference between a rubber duckie antenna mounted at the proper
place in front of a reflector and a pre-built dish that has a dipole as the
feed element.
As far as cans as waveguides, most of my experience is with the 90 ton
dish on top of Mt. Umunhum. That had a 9" circular waveguide delivering
substantial power to a reflector that was probably fifty feet away from the
end of the waveguide.
"At Almaden, California, testing of an AN/FPS-24 radar could only be
conducted at times when the local television stations were not
broadcasting."
http://mail.the-kgb.com/dante/military/milpics7.html
Their die cast dish antennas are fine. No clue who made them.
I'm partial to Pacific Wireless dishes:
http://www.pacwireless.com/products/directional.shtml
http://trevormarshall.com/biquad.htm
I don't like yagi's. They're too narrow bandwidth, have side lobes
all over the place, usually have boresight errors, and are
rediculously long for any reasonable gain. At 15dBi gain, I would use
a panel antenna or dish. At 24dBi, the only viable option is a dish
because a yagi would be about 20ft long. For the same price as the
Antenex yagi, you can get a much higher gain dish.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com
# jeffl@comix.santa-cruz.ca.us
# 831.421.6491 digital_pager jeffl@cruzio.com AE6KS
On Tue, 14 Sep 2004 04:10:19 GMT, Jeff Liebermann
Sigh. I gotta hire a better proof reader.
A 24dBi yagi would be about 20 wavelengths long or about 2.5 meters
long. One of my reference books claims 16dBi is about the practical
limit for yagi antennas. Any longer boom length and the gain increase
is fairly nominal. For example, to get 3dB more gain, the boom length
of the antenna must be more than doubled.
On Mon, 13 Sep 2004 22:46:26 +0000 (UTC),
My measurements show the DWL-122, with an SMA connector in place of
the PIFA antenna, belches about +13dBm. My Orinioco (pre-Proxim)
Silver card puts out +15dBm. While my absolute measurement accuracy
is probably off, the relative numbers are quite accurate.
Differnt types of antennas with identical gains will deliver identical
power levels "to a point" regardless of the beamwidth.
It really depends upon what you're trying to do with the antenna. If
you're doing point to point, then a narrow beam is highly desireable.
However, if you're trying to illuminate a distant "area", more
beamwidth is desireable. In general, for a given gain antenna, a
narrower beamwidth implies lots of side lobes, or crummy efficiency.
I went through a few of the antennas on the fab-corp.com web pile.
Antenna gain vert
beamwidth
Dish 15dBi 19deg
Microcepter 16dBi 27deg
Rootenna 14dBi 35deg
Arc Wireless 13dBi 38deg
Not exactly a perfect comparison, but close enough to illustrate the
point.
>broadcasting."
Argh. I've lived in Ben Lomond since about 1974. When I first moved
in, I could see the big rotating dish on Umunhum out my window. Every
time it came around, I could hear the buzz on every radio in the house
and on some resonant wires around the house. I couldn't record
anything without adding the buzz. Good ridance.
On Mon, 13 Sep 2004 23:53:06 -0700, Jeff Liebermann
Duh. Forgot to add a yagi antenna:
Antenna gain vert
beamwidth
Dish 15dBi 19deg
Maxrad yagi 15dbi 30deg
>> radio comes close.
have you seen plans for an 8 or 16 element panel antenna?
I have the materials,copper in sheet and tape form but can't find
dimensions for anything beyond one element.
> I've noticed that.
> feed element.
> broadcasting."
So, if that really is a -4dBi (although I can't remember if that was the
DWL-122, or a different one), then you are saying the Orinoco is +6dBm over
the stock DWL-122, where the manufacturer specs say differently.
In any case, it is not as large a difference as you indicated in the
earlier post, and this is just a litlle itty-bitty USB adapter.
But the tighter beamwidth antennas tend to be higher gain.
I think I was getting two threads confused on Monday. The other thread was
trying to go point to point between two buildings.
>>broadcasting."
Think about living on the base... you subconsciously blinked every 5
seconds to avoid looking at the junk on the TV screen.
You have been a wealth of information. From your advice, I'm
considering the following:
1) the http://www.rangeextender.com/219pagransy.html with the "2.4GHz
19dBi Parabolic Grid with N Male Pigtail" connector.
2) The "U.FL Hirose, IPAX to N Female Bulkhd 6 in Pigtail" from
fab-corp. couldn't find this anywhere else. (I don't understand the
"Bulkhd 6" term so I have an e-mail to them asking)
3) Possibly the "LMR-400 NM/NF 50 Foot Jumper" from fab-corp as well.
I think you or someone else mentioned this coaxial for minimum loss.
The questions is that if the antenna is a 19dBi, what loss can I
expect? (assuming that it is measured on this scale). This will allow
me to mount this in my attic and keep it out of site.
Thanks again for the help!
That would be a six inch cable, ending in a BulkHead connector, designed to
be mounted in a chassis. It would work for this application if you really
were that close to the antenna, which I doubt.
Or it would serve as a way to securely mount this "duty rated" N connector
near to the PC Card and attach the IPAX to your PC Card once. FAB warns
that that IPAX connector is not rated for repeated plug/unplug. Then you
would run a NM/NM cable to the Female N of the PMANT19PF1 instead of
getting a pigtail on the antenna.
So, why am I not wealthy?
I dunno if you need it to be small or portable, but if you want gain,
go for the 24dBi incantation:
http://www.rangeextender.com/224pagransy.html
for $9 more.
Well, neither do I. I think it means an N connector meant to be
mounted on a bulkhead, also known as a panel, box, wall, case, or
thing.
Did you catch this note?
"Special note with the U.FL connector - these are NOT a duty rated
connector. Once it is connected it is strongly suggested to leave it
connected. Due to its size and design its use in a plug and unplug
situation will be very limited and will not be covered under
warranty."
Ugh. Keep the coax cables short. Do you really need 50ft of cable?
At 7.8dB/100ft, you will lose slightly more than half your power (and
sensitivity) in that hunk of coax.
You're framing the question wrong. Coax loss has little to do with
antenna gain. They're independent, but they do add together. For
example, if you have 19dBi of antenna gain, but -5dB of assorted cable
and connector losses, you'll have +14dB of improvement, which is quite
a bit.
Do the math, er... arithmetic:
-0.66dB/ft for LMR-400 coax. 50ft will be -3.3dB
-0.5dB per connector pair. You will have 3 pairs of these for a
total connector loss of -1.5dB.
-1.0dB is my guess(tm) for the pigtail coax loss.
To give you a rough guess at the anticipated improvement, the antenna
gain of your DWL-650 is about -2dBi (yeah, that's 4dB worse than a
dipole). The transmitter probably belches +15dBm. So your current
laptop radiates:
+15dBm -2dBi = +13dBm
With the dish antenna, we have:
+15dBm -1.5dB -3.3dB +19dBi = +29.2dBm
That's an improvment of:
+13dBm - 29.2dBm = 16dB
16dB may not seem like much, but it's really 40x times your power
output. In terms of range, you double your range for every 6dB, so it
will be about 6 times the range.
> I haven't done any real (or reproducible) range tests with my
> collection of adapters. However, the few that I tried show that the
> Orinico cards are among the best. Only the high power Senao cards
> seem to have better range. I attribute this to the elevated antenna
> design in the Orinoco cards (but might be wrong).
I agree that the Orinoco seems the best of the ones that I have used,
either in somewhat careful comparisons or the "can I connect from the
Starbucks Parking lot?" test. On the other hand, the mini-USB offers a
cheaper and better long range solution when coupled with a free coffee can.
> Wrong. Beamwidth and antenna gain are NOT related. Antennas do not
Where is the 24dBi patch panel? There are 24dBi dishes readily available.
That's what I mean.
If you want a building to building connection, there is no purpose served
by an omni, regardless of gain, or a patch, or a sector. The tightest
possible bandwidth will deliver the highest power to the other antenna
because, for a given price and size, it will be the highest gain.
The antenna doesn't produce power, but there is no point in sending what
power you have to places other than the point where you want it.
Cruising fab-corp.com quickly
10 dBi Omni Directional Antenna
On Wed, 15 Sep 2004 15:52:32 +0000 (UTC),
>That's what I mean.
Oh, that. That still has nothing to do with beamwidth. Different
technologies and construction methods have their own limitations. A
typical single patch antenna has +8dBi gain. Double the number of
antennas to add 3dB more gain. So, the number of patches required for
24dBi would be:
Gain Number
dbi of patches
8 1
11 2
14 4
17 8
20 16
23 32
Including clearance, an air dielectric 2.4GHz patch requires about
6"x6" per patch. So the 23dBi panel will be 8 square feet in area.
4x8 patches seems a good arrangement, so we get a 24" x 48" panel
antenna. Using TFE/ceramic dielectric instead of air, the antenna
will be about half this size. Here's one with two patches on
TFE/ceramic circuit board:
http://www.LearnByDestroying.com/p [...] 25e-1.html
The board is 4.5"x6.8".
Big patch antennas exist but are tricky to make. The big headache is
feeding the 32 patches in phase. That requires carefully controlled
cable lengths or circuit board traces. The cables are difficult and
expensive to make, while the circuit board traces require additional
board real estate.
The required power splitters are also lossy. You can build an array
of 4ea 17dBi antennas to almost get the required 23dBi gain. A simple
Wilkinson power splitter will do the combining externally. You'll
lose about 0.5dB per combiner or 1.5dB for the 3 combiners required
for a 2x2 array of common 17dBi antennas. The end result will be a
21.5dBi antenna instead of a 23dBi antenna. To make up the 1.5dB
loss, all you need to do is add two more 17dBi antennas , resulting in
an 6 antenna array. However, that would required additional lossy
power splitters, so the final power output would still be less than
23dBi. This is one reason you don't see really big high gain arrays
of panel antennas.
You won't realize those 3dB steps all the way up.
Other losses start to creep in, and all the combiners aren't perfect.
Just something to be aware of.
KC6ETE Dave's Engineering Page, www.dvanhorn.org
Microcontroller Consultant, specializing in Atmel AVR
The high dBi antennas tend to have tight beamwidth. That's what I mean.
9.5 dBi 90 deg Sector Antenna $ 65.00
10 dBi Omni Directional Antenna 45 Inches Long $ 79.99
11dBi MICROCEPTOR Panel $ 57.99
15 dBi Yagi $ 58.99
24 dBi Parabolic Grid $ 59.99
(ignore this one, it doesn't fit my argument ;-)
19dBi Patch Antenna $ 47.00
Home made cans are harder to quantify because of haphazard testing
conditions, but they certainly are cheap. Around 10-16 dBi?
A "shootout" comparison:
http://www.turnpoint.net/wireless/has.html
http://www.oreillynet.com/pub/wlg/1124
My own chili-can antenna on an Orinoco shows 12dB gain in signal, and a
14dB reduction in noise. Two chili cans increased the signal by 1, to
13dB, but offered another 4 dB in noise reduction.
Oops... posted that by accident while I was checking some notes.
Antenna design is a beautiful example of the fact that engineering is the
art of compromise.
While tight beamwidth does not require high gain, high gain requires some
sort of compromise elsewhere, and the easiest place to compromise is on
beamwidth. Even omnidirectional gain antennas compress their radiation
pattern twoard the horizon, to achieve the gain.
On Wed, 15 Sep 2004 12:23:05 -0500, "Dave VanHorn"
Yeah, I know. I also screwed up in my numbers. It's 0.5dB loss per
port. So, a 4 panel array will have 3 Wilkinson combiners/splitters
for a total of 6 ports, each with 0.5dB loss or 3dB loss for the
entire array. To make up for the 3dB loss, just DOUBLE the size of
the array. Ugh.
Unfortunately, that's about the only way to do it with 50 ohm panels.
If on a single circuit board, the most common way is to use 4ea of 200
ohm patch antennas, and combine them in parallel for a total of 50
ohms. The traces are 200 ohms (which tend to be tiny) and they all
meet at one point. Loss is much less as there's no combiner/splitter.
A friend of mine does ham radio contesting in that band.
He has a 70' tower, with the actual radio mounted up at the top of the
tower, feeding the array of yagis through matched cables and the combiner
network.
We're allowed 1500W in that band, but that would be inordinately expensive.
I think dave uses 10-20W. He goes out as far as texas, from central
indiana.
Of course that's an exceptional day, just the right conditions, and only
morse code, or sideband voice, not high bandwidth data. High bandwidth eats
range.
I would expect that if you reduce your bandwidth, you should get better
range, unless they are using the same modulation scheme, and just slowing
down the data..
> beamwidth.
Exactly. I think of it as a finite bunch of excited electrons bumping into
other electrons on their way "out". You can send them everywhere, or you
can focus their anxiety on a single path toward the other antenna.
"tommy" <tommynospam@yahoo.com> schreef in bericht
news:4f0df91b.0409141749.56d96ea6@posting.google.com...
If you mount it in the attic, significant loss will occur when the signal
passes the ouside wall or the roof.
Can you position it so that it looks through a window to your neighbour?
gr, hwh
That was a concern to me too. I'll either settle for loss and stick
it in the attick or just mount it on the same pole as my TV antenna
(that I never use since I have DirecTV).
> for $9 more.
I'm still trying to decide on this one. Not sure yet. I guess it
would make sense for the money.
> thing.
it means it is a 6" pigtail. they also have 12". they were kind
enough to respond to my 2nd e-mail within 24 hours instead of the 3
days it took on my first.
> warranty."
Yup, saw this. That's why I'm looking for one about 2 inches long to
permanently afix to my DLink card.
half? at -3.9db/50ft with a 19dbi antenna, would't that be -15.1db?
On 15 Sep 2004 20:20:21 -0700, tommynospam@yahoo.com (tommy) wrote:
>they were kind
Fab-Corp is in New Port Richey, on the Florida west coast, which was
suppose to be in the path of hurricane Charlie. They evacuated nearby
Tampa. A week later, Francis arrived.
If you don't mind permanently, then methinks butchering the card and
soldering on a pigtail would do as well. Just a thought.
No. Just the coax cable. Also, I screwed up slightly with the
numbers. The loss of LMR-400 is closer to 6.6dB/100ft (not
7.8dB/100ft). 50ft of coax cable would be half of that or 3.3dB/50ft.
I got the attenuation right in the calculation examples at the bottom
of my previous posting, but screwed it up earlier in the page.
The antenna is treated seperately and as part of a system. See my
previous posting where I added it all up (near the bottom).
Here's a new wrinkle:
Hawking HWU54D Hi-Gain Wireless-G Directional USB 2.0 Network Adapter
http://www.hawkingtech.com/prodSpec.php?ProdID=208
HAI6SDP Directional 6dBi WiFi Antenna with a built in
HWU54G Wireless-G USB2.0 Network Adapter
http://www.digitallyunique.com/hwu54d.html $57.95
http://www.compusa.com/products/pr [...] &pfp=srch1
Well, got my stuff today (oddly enough bought the stuff from two
different places and arrived on the same day) and hooked it up. That
damn U-FL connector seems so flimsy that I'm not convinced it's making
full contact with my dlink connector. Ugh I hate that thing. Might
upgrade just to avoid having to use that.
Anyway, they had two schemes for building the antenna. Horizontal or
vertical polarization. How do I determine which one I need?
Well, you could also butcher the existing card and attach a coax cable
and connector (pigtail) instead of using the U-FL connector.
It all depends on what's on the other end of the link. If the access
point antenna(s) are vertical, then you use vertical. The only reason
you would use horizontal is if you were trying to avoid interference
from other nearby users that are most commonly using vertical
polarization.
Probably vertical, but it helps to match the other end. Some antennas are
quite sensitive to proper orientation. My Orinoco laptop gets noticeably
better signal if the external antenna on my WAP is horizontal. I can't
easily change the laptop, so my WAP is horizontal. My USB DWL-122 is
sensitive, but it can be oriented either way, so I match the WAP with it.
If you have control over both ends, try both. One might get less
interference from other noise sources in your area.
There are 2087 identified and unidentified users. To see the list of identified users, Click here.
By Ubrales, 7 days ago:
Yes it will work fine! Earlier this week I installed two Linksys AE1000 wireless...
Area51reopened - gold Expert
Specialties : Storage, WiFi, Win 7, Applications, Systems, Win Vista, Win XP, Peripherals
15216 messages since 1970/01/01
hang-the-9 - bronze Expert
14008 messages since 1970/01/01
