I recently purchased an Antec 1080 AMG case from an online retailer with an Antec TruePower 550 PS, that I plan on using for an Athlon XP/nforce2 setup. It came in today, and eager to put it to use (and make sure the PS was working) I moved my old components from a <cough> Dell into the new case. I know it is an injustice to the case, but just for a week. OK, so I moved all of my components, and plugged in the power supply, turned on the switch on the back of the power supply, and pressed the power switch on the PS, and then for the case, NOTHING. I looked the install over thoroughly to make sure I didn't miss something, NOTHING. I plugged in the old PS from the Dell, and pressed the power switch on the case and presto. What could I be missing? How can I tell if the new PS works properly without trying it with another MB setup? Can it be done? Help. I can provide more detail if necessary.
Thanks.
Thanks.
