Would a radiator for a v6 cause a 350 engine to run hot
  • Engine
  • Cars
Last response: in Cars
Anonymous
October 25, 2010 7:53:13 AM
would a radiator for a v6 chevy camaro cause a 350 engine to run hot
More about : radiator 350 engine run hot
October 25, 2010 2:06:45 PM
Your joking right?
m
l
October 25, 2010 9:13:48 PM
This topic has been moved from the section Overclocking to section Cars by Arthurh
m
l
November 8, 2010 5:52:34 PM
What are the parameters,is the v6 rad. new or used, if used were the tubes roded out before the install. Were you having an over heating problem with the old rad. on the 350? What kind of fan does the 350 have on it a flex or a clutch fan,does it have a fan shroud & is fan located in the shroud or out of the shroud. Have you tried test running it without the thermostat.If the vehicle has an A/C condenser does it have good air flow no obstructions for the air to flow to the radiator.
m
l
November 8, 2010 6:13:05 PM
If your water pump, thermostat, and fan are working properly, then the radiator should be fine. What is the problem you are experiencing? Please elaborate.
m
l
November 10, 2010 3:08:26 AM
A couple things to think about.
the V6 core from a car or truck? a car radiator is lighter duty than a truck radiator.
is it a side flow radiator or vert. flow? side flow radiators will be a bit more efficient than others.
and the obvious,, is it clean and in good working order?
Auto trans or manual? if its auto, DONT use the built in trans cooler tube, get an external trans cooler. (manual trans uses no cooler)
I have built a V8 vega and used a side flow V6 radiator from a pick-up, installed 2 electric fans on it and a high flow water pump, my car would run a bit hot in town sitting at lights, (225'-240) but when moving I never had a problem (220')..
anything 250'+ is TOO hot, but there are things you can do.
fan shrouds, ducting, and sometimes you can remove the thermostat, punch out the center part and replace it, that way you still have a bit of restriction needed for cooling and unless you live in a cold climate you wont have winter heater problems.
m
l
