Ok, I got:
Abit IC7
3.0c
AIW R9700 Pro
an Antec case with truepower 430 watt
120gb WD
some sony 16x dvd drive
some sony floppy
2x512mb kingston hyperx pc3500 ram
some cheap belkin nci card, which I only put in the PCI slot but didn't connect the power cable(where the heck is the power for the pci device on this board anyways~!)
I tried my best t put them together and when I try to boot up, it will keep giving off this "bee-boo-bee-boo" sound non-stop then after 5 sec or so it will shut down. Damn it! What is wrong!? Could it be that I connected the cables wrong or something? I connected that really thick cable from the PSU to the motherboard. Then connected the fans to the cables with "FAN ONLY", and I connected the 9700 pro to one of the cables, and then at the other to the harddrive. The board comes with round cables. I connected the floppy one to the floppy and then to the mobo, this I did correctly. I also connected the IDE cable to the DVD drive(master end) to the HD(slave) then to the motherboard's 1st IDE slot. Can anybody help me!? I didn't set any jumpers for the HDD because I don't know how to nor do I know where are they! Somebody help me! This rig cost me 2k and it would suck to not being able to run it
Sorry I don't mean to spam all the forums but I REALLY NEED HELP
Abit IC7
3.0c
AIW R9700 Pro
120gb WD
some sony floppy
