Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
Well, the memory sure made it run faster - currently have 512mb (that is the
max Gateway says this machine will handle) and response time is great.
However, there is no change to the two issues below. If I right click on the
desktop or if i select the File command in Windows explorer the machine
"hangs" (hourglass) for about 30 - 45 seconds, closes all open applications,
and brings me back to the desktop as if I had just booted up....
The only other thing that does not seem to work since the upgrade from ME to
XP is sound. I have an SB Live! soundboard from Creative that came with the
unit. I have gone to their site and downloaded a full driver that was
supposed to work with XP but there is still no sound. I can buy a new sound
board easy enough but any hints here would be great. The first problem is
the most annoying though, so if you have any other ideas there I will
DEFINATELY try them out!
"Colin Barnhorst" wrote:
> *That is...
> Colin Barnhorst [MVP Windows - Virtual Machine]
> (Reply to the group only unless otherwise requested)
> "Colin Barnhorst" <colinbarharst(nojunk)@msn.com> wrote in message
> news:%23LaHJTXMFHA.1308@TK2MSFTNGP15.phx.gbl...
> > That in not on-board (integrated with the motherboard). That is add-in
> > (card that sits in a slot). Let us know about the memory. It will
> > improve performance. If you have problems booting after adding the ram,
> > try with one card out.
> > "DJHMcKinney" <DJHMcKinney@discussions.microsoft.com> wrote in message
> > news:A472537B-B0F5-434F-AB5D-EAE96467555D@microsoft.com...
> >> It is an onboard card. I put in a new one about 2 months ago as the
> >> original
> >> one "died". Nothing fancy since we don't do games or anything, basically
> >> a
> >> simple replacement of the one that ws in there. The video card stats
> >> displayed during boot-up indicate something about 64mb... Not sure that
> >> does
> >> you any good.
> >> Anyway, I would absolutely LOVE it if it were simply a memory issue. My
> >> wife just called and the memory arrived today. I will test it out
> >> tonight!
> >>> What video card? If it is onboard video then adding memory may resolve
> >>> some
> >>> of the 'hanging' since you may only be using 96mb of ram for the system,
> >>> but
> >>> watch your power supply. Make sure you don't exceed its rating.
> >>> news:0831167B-6273-46F2-AA93-735132D9AB37@microsoft.com...
> >>> > It is a Gateway - P866. 866 mhz CPU, 128mb RAM (I have ordered 2 -
> >>> > 256mb
> >>> > cards that should be here in a day or two), 40gb disk - with 65% free
> >>> > space.
> >>> > I defrag'd after the XP install.
> >>> >> Don't keep doing something that isn't fixing the problems. I have
> >>> >> had
> >>> >> difficulties in the past upgrading from ME to XP. Describle your
> >>> >> computer
> >>> >> (make and model, ram, cpu, hard drive type, etc).
> >>> >> message
> >>> >> news:83013410-2740-4B00-80D3-5A7CBD51BCF5@microsoft.com...
> >>> >> > Upgraded from ME to XP Home with SP2. After I rebuilt my address
> >>> >> > list
> >>> >> > (luckily i had zipped my messages) I have notice 2 problems that
> >>> >> > are
> >>> >> > likely
> >>> >> > related. If I right-click on the desktop (arrange icons, etc.) the
> >>> >> > system
> >>> >> > hangs and then refreshes itself - almost like I logged off and
> >>> >> > logged
> >>> >> > back
> >>> >> > on.
> >>> >> > A second (related?) problem is that if I am in Windows Explorer and
> >>> >> > select
> >>> >> > File (to create a new folder, etc.) it does the same thing. I can
> >>> >> > install
> >>> >> > a
> >>> >> > new folder in an MS Office "save as" screen, but not from the File
> >>> >> > command.
> >>> >> > I have already reinstalled XP once - first time Outlook Express
> >>> >> > displayed
> >>> >> > messages but you could not open them. I hate to reinstall again if
> >>> >> > somebody
> >>> >> > has an idea...
> >>> >> > THANKS!!!
