Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
XYZ <XYZ@discussions.microsoft.com> wrote:
>I had this tower built by a local shop. What I need to know is what is the
>completet documentation, disks, manuals etc. that I should have received? The
>OS is Win.XP Pro wSP1, Office 2000 Premium. I received nothing at time of
>purchace. With my older computer from Gateway I received all the disks,
>books, all required registration numers. Please advise. Thank you. XYZ
You can expect to be provided with *a method* by which the computer
can be restored to "factory new" status including a freshly installed
copy of Windows.
This can be accomplished by any of several means including:
- A Windows XP OEM Installation CD plus product key.
- A Windows XP "System Recovery" CD containing a compressed image file
of the installed Windows, just as it was when it left the factory.
- A hidden "System Recovery" partition on the hard drive that contains
the compressed image as per above.
If you did not receive one of the above items with your computer then
you have been shortchanged at least and you should return to where you
purchased it and inquire about the Windows XP reinstall method.
If you do not get a satisfactory result from this then your next
recourse is to report the vendor to piracy@microsoft.com This will
not help you to resolve your problems with the installation of Windows
but you should at least get the satisfaction of knowing that this
vendor has been forced to correct his ways, or has been put out of
business.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
