Defraging Problems!!!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I have windows XP Home edition. One of my buddies built my computer
around 2 months ago and has a Western digital 120gb HD. I tried to
Defrag my computer today before I went to work. Before I left it was up
to 6%. Came home and found that there had been a serious error and my
computer had restarted. Tried to defrag again only got to 3% this time
before restart. Tried again same issue. No other programs were
running, including my screen saver. Currently have 64% of my HD free.
Please Help Me Figure this out.
Goof2003
G
Guest
Guest
Hi,
Run a disk check. Click start/run and type cmd, then click ok. At the
prompt, run "chkdsk C: /r" (without the quotes). You will not be able to
dismount the drive while Windows is running, so follow the prompts to
schedule it to occur on a system reboot. Then reboot.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Goof2003" <Goof2003.1mmnpn@pcbanter.net> wrote in message
news:Goof2003.1mmnpn@pcbanter.net...
> Goof2003
G
Guest
Guest
It is very unlikely that your computer needed defragging
after two months of use. Not impossible, just VERY
unlikely.
You may have a hard drive problem though. Get the
diagnostics program from the manufacturer (Western
Digital) and run it.
Good Luck !
>-----Original Message-----
my computer
I tried to
left it was up
error and my
3% this time
programs were
my HD free.
>Goof2003
G
Guest
Guest
Run Defrag from Safe Mode.
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com./athome/security/protect/default.aspx
http://defendingyourmachine.blogspot.com/
Ros
29
Have you got a cable modem? I had this problem. Cured by unplugging the
modem, and turning off firewall/virus checker for good measure. it worked.
RoS
