Archived from groups: alt.internet.wireless (More info?)
Hi!
I have a laptop (Compaq Presario 2100) with an built-in LAN Express
wireless network adapter. This gives a very faint signal, but it works
because it does not vary when the computer sits on my desk.
I tried to make the signal stronger by buying a Netgear MA521 cardbus
card. It made the signal a lot stronger, but the signal varies from
full signal to no signal without doing anything! It makes my
connection go away every now and then, very annoying.
This is a Network Stumbler analysis from the LAN Exress adapter:
As you can se, the Netgear card signal varies some 35dB, whereas the
LAN Express varies only some 5dB (even less, the -80dB hump was me
moving away from the computer) and never goes away.
