Tom's Hardware > Forum > Mobility Networks > Verizon > Best Phone for Battery Life?
Forum Mobility Networks : Verizon - Best Phone for Battery Life?
Archived from groups: alt.cellular.verizon (More info?)
What is the best phone as far as battery life goes (and a decent phone as
well)? I should mention that I do need a phone that can be used as a modem!
thanks for you help
Sponsored Links
My Sony Ericsson T637. I get a solid 8 hours of talk time and if I don't use
it much can standby for about 2 weeks. Yes, these are consistent numbers.
And guess what? Verizon doesn't carry any models like this of course....
"Josh Grameson" <moon248@borderlessgroup.com> wrote in message
news:OplCc.7202943$iA2.814064@news.easynews.com...
modem!
> thanks for you help
Reply to Anonymous
- 0 +
Only two weeks but I like my LG6000. Most I went was three days to
half charge. Didn't use it much.
On Thu, 24 Jun 2004 15:23:43 -0400, "Killer Madness"
>modem!
>> thanks for you help
Reply to sbs
On Wed, 23 Jun 2004 20:07:10 GMT, "Josh Grameson"
>thanks for you help
The Kyocera 6035 at 5 hours talk, 180 hours standby.
Evan
To reply, remove TheObvious from my e-mail address.
Reply to Anonymous
"Evan Platt" <evan@TheObvious.espphotography.com> wrote in message
news:7113e0d3838gi4ak336qnbajbtr3gp8bce@4ax.com...
modem!
> >thanks for you help
> Evan
.....but after 3-4 hours, you'll have to talk really loud because the battery
is running pretty low...
Dan'l.
Reply to Anonymous
- 0 +
"Josh Grameson" <moon248@borderlessgroup.com> wrote in message news:<OplCc.7202943$iA2.814064@news.easynews.com>...
> thanks for you help
I just picked up an LG VX4400B. I had heard of some complaining about
battery life, but after my 1st full (12 hr) charge I went from full
charge down to 1 bar within about 12 hrs, with less than an hour of
talk time. I'm a little concerned/worried about that. I hope it gets
better than this!
Reply to Mike
- 0 +
I bought the extenden life battery for this phone.
Larry E.
>>thanks for you help
> better than this!
Reply to Larry
On Tue, 29 Jun 2004 15:16:06 GMT, "Daniel Dravot"
>modem!
>> >thanks for you help
>> Evan
You'll be talking loudly long before then, because the battery will
probably be too hot to hold the phone up to your ear comfortably.
Reply to Anonymous
>> thanks for you help
>better than this!
I assume you had it on during those 12 hours. If so, what is the
signal level like in your area? A low CDMA signal will cause the
phone to use more power.
Reply to Anonymous
- 0 +
Larry <Larry@nospam.net> wrote in message news:<iPnEc.47114$OT6.18758519@news4.srv.hcvlny.cv.net>...
> Larry E.
> >>thanks for you help
> > better than this!
Josh....just wondering if you got similar battery life on the standard
battery? It just seems awful short, when compared to the "claimed"
battery life. I even tried to lessen some of the contrast settings
and I know I was NOT in Analog mode. I think the "claim" is approx
180 min talk and 110 standby? I am barely a fraction of those
numbers. I did call Verizon and they said that this is not close to
correct. I called the store and they have swapped the battery, and
they said if this continues, then to go back and they will swap the
phone itself.
Reply to Mike
That was actually my first guess. :)
>phone itself.
If they wind up swapping the phone, make damn sure they swap out the
charger, too. While unlikely, I wouldn't completely rule out the
charger as being at fault.
Reply to Anonymous
- 0 +
The Ghost of General Lee <ghost@general.lee> wrote in message news:<vvq5e0pmq6bt1cc2od42hcur0o8ek165lo@4ax.com>...
> >> thanks for you help
> >better than this!
Yes I did have the phone on. As far as signal strength....obviously I
can't say exactly for the full 12 hrs, but typically it would show on
average about 3 bars.
I did end up calling VZW CS and they agreed that this was well below
what it should be. I also called the store (a local Phones + in CO).
The guy that sold it to me said to just bring it in, as he agreed that
what I had was too premature. He swapped the battery and said to try
the new battery, and said if that doesn't work, then he'd swap the
phone. If it gets to that, then I will remember to also swap
chargers! Thanks for the advise!
After my first charge and about 14 hrs standby and maybe 30 min of
talk, it has only dropped 1 bar....so that alone is a major
improvement over the last one. I'll keep you posted!
Reply to Mike
On Tue, 29 Jun 2004 08:01:24 -0700, Evan Platt
<evan@TheObvious.espphotography.com> chose to add this to the great
equation of life, the universe, and everything:
But after 180 hours of standby, your talk time is more like 5 minutes?
David Streeter, "an internet god" -- Dave Barry
http://home.att.net/~dwstreeter
Remove the naughty bit from my address to reply
Expect a train on ANY track at ANY time.
"Don't go poking your nose into my finger." - Hawkeye to Radar
Reply to Anonymous
Josh,
Nokia 3589i does both. Battery life standby time 2-3 days even after
60 minutes of calls. If you want a flip phone, one with camera, or
games, this phone is not.
Scott
> thanks for you help
Reply to Anonymous
There are 1323 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
