Java problem
Forum Games General : PC Gaming - Java problem
Allright so I've trying to play some games my friends are playing. The game is moparscape. Its where people took Runescape, and made there own private server of it. For the games you must have JAVA. I have the newest version of java. Once you have JAVA you download the client for the server(all servers start the same way). Once you download the client you open the folder and click on the File Run(its a windows BAtch file). It will open the client, once your on you make your acc and login. Now heres the trouble. Once i login i can stay loged in for around 1min. Then the Client closes out. I re-open the folder and a new file is located about RUN.
The file is called hs_err_pid3228 (the number is always different). This is what the file says
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000006d8418c6, pid=4056, tid=4964
# JRE version: 6.0_14-b08
# Java VM: Java HotSpot(TM) 64-Bit Server VM (14.0-b16 mixed mode windows-amd64 )
# Problematic frame:
# V [jvm.dll+0x518c6]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x000000002a4e2000): JavaThread "CompilerThread0" daemon [_thread_in_native, id=4964, stack(0x000000002aaf0000,0x000000002abf0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000000000
Registers:
EAX=0x0000000034903de0, EBX=0x0000000032fb4fd0, ECX=0x0000000034903db0, EDX=0x000000002abec8a0
ESP=0x000000002abec440, EBP=0x000000003277ea50, ESI=0x000000002abec8a0, EDI=0x0000000034903db0
EIP=0x000000006d8418c6, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x000000002abec440)
0x000000002abec440: 000000000000006a 000000006db67232
0x000000002abec450: 0000000035d1bd40 000000006db589cf
0x000000002abec460: 000000002abec8a0 0000000000000000
0x000000002abec470: 0000000000000000 0000000000000000
0x000000002abec480: 00000000328de250 000000006dba9a05
0x000000002abec490: 0000000032fb4fd0 0000000000000002
0x000000002abec4a0: 000000002abec8a0 0000000034903db0
0x000000002abec4b0: 000000002abedcc0 0000000000000000
0x000000002abec4c0: 000000002abec8a0 000000006dba8c64
0x000000002abec4d0: 0000000032fb4fd0 0000000000000003
0x000000002abec4e0: 000000002abec8a0 0000000034903db0
0x000000002abec4f0: 000000002abedcc0 000000002a49c2b0
0x000000002abec500: 000000002abee670 000000006db1b448
0x000000002abec510: 0000000032fb4fd0 0000000000000001
0x000000002abec520: 0000000032fb4fd0 000000002abedcc0
0x000000002abec530: 0000000000000000 0000000000000000
Instructions: (pc=0x000000006d8418c6)
0x000000006d8418b6: e0 48 8b 41 08 4c 8b 60 08 48 8b 68 10 4c 8b f1
0x000000006d8418c6: 49 8b 04 24 49 8b cc 45 0f b6 f8 48 8b fa ff 10
Stack: [0x000000002aaf0000,0x000000002abf0000], sp=0x000000002abec440, free space=1009k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V [jvm.dll+0x518c6]
Current CompileTask:
C2:406 client.method85(IIIIIIIIIIZI)Z (1957 bytes)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x000000002a4fa800 JavaThread "Thread-8" [_thread_blocked, id=3872, stack(0x0000000035870000,0x0000000035970000)]
0x0000000032608000 JavaThread "Thread-7" [_thread_blocked, id=4892, stack(0x0000000034cc0000,0x0000000034dc0000)]
0x000000002b7e0800 JavaThread "Thread-6" [_thread_blocked, id=3056, stack(0x0000000033bf0000,0x0000000033cf0000)]
0x000000000104b000 JavaThread "DestroyJavaVM" [_thread_blocked, id=5048, stack(0x0000000002450000,0x0000000002550000)]
0x000000002b58c800 JavaThread "Thread-4" [_thread_in_Java, id=3768, stack(0x00000000318d0000,0x00000000319d0000)]
0x000000002b528000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=3788, stack(0x0000000031350000,0x0000000031450000)]
0x000000002a5ec800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=3784, stack(0x00000000310b0000,0x00000000311b0000)]
0x000000002a5ea000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3772, stack(0x000000002bba0000,0x000000002bca0000)]
0x000000002a5e9000 JavaThread "AWT-Shutdown" [_thread_blocked, id=3792, stack(0x000000002baa0000,0x000000002bba0000)]
0x000000002a5e4800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=1992, stack(0x000000002b8d0000,0x000000002b9d0000)]
0x000000002a571800 JavaThread "Thread-1" daemon [_thread_blocked, id=4972, stack(0x000000002b290000,0x000000002b390000)]
0x000000002a50e800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4456, stack(0x000000002acf0000,0x000000002adf0000)]
0x000000002a4f9800 JavaThread "CompilerThread1" daemon [_thread_blocked, id=4500, stack(0x000000002abf0000,0x000000002acf0000)]
=>0x000000002a4e2000 JavaThread "CompilerThread0" daemon [_thread_in_native, id=4964, stack(0x000000002aaf0000,0x000000002abf0000)]
0x000000002a4de000 JavaThread "Attach Listener" daemon [_thread_blocked, id=4908, stack(0x000000002a9f0000,0x000000002aaf0000)]
0x000000002a4dd000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2916, stack(0x000000002a8f0000,0x000000002a9f0000)]
0x000000000089d000 JavaThread "Finalizer" daemon [_thread_blocked, id=5080, stack(0x000000002a7f0000,0x000000002a8f0000)]
0x000000002a494800 JavaThread "Reference Handler" daemon [_thread_blocked, id=5004, stack(0x000000002a6f0000,0x000000002a7f0000)]
Other Threads:
0x000000002a491800 VMThread [stack: 0x000000002a5f0000,0x000000002a6f0000] [id=4960]
0x000000002a510000 WatcherThread [stack: 0x000000002adf0000,0x000000002aef0000] [id=4412]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 62656K, used 13066K [0x000000001f770000, 0x0000000024fc0000, 0x0000000029e10000)
eden space 36544K, 35% used [0x000000001f770000,0x0000000020432af8,0x0000000021b20000)
from space 26112K, 0% used [0x0000000023640000,0x0000000023640000,0x0000000024fc0000)
to space 26944K, 0% used [0x0000000021b20000,0x0000000021b20000,0x0000000023570000)
PSOldGen total 99136K, used 80617K [0x000000000aa10000, 0x0000000010ae0000, 0x000000001f770000)
object space 99136K, 81% used [0x000000000aa10000,0x000000000f8ca520,0x0000000010ae0000)
PSPermGen total 21248K, used 10379K [0x0000000005610000, 0x0000000006ad0000, 0x000000000aa10000)
object space 21248K, 48% used [0x0000000005610000,0x0000000006032c28,0x0000000006ad0000)
Dynamic libraries:
0x0000000000400000 - 0x000000000042e000 C:\Windows\system32\java.exe
0x00000000770b0000 - 0x0000000077230000 C:\Windows\system32\ntdll.dll
0x0000000076eb0000 - 0x0000000076fdc000 C:\Windows\system32\kernel32.dll
0x000007fefec70000 - 0x000007fefed78000 C:\Windows\system32\ADVAPI32.dll
0x000007feff250000 - 0x000007feff38f000 C:\Windows\system32\RPCRT4.dll
0x000000006d7f0000 - 0x000000006de4d000 C:\Program Files\Java\jre6\bin\server\jvm.dll
0x0000000076fe0000 - 0x00000000770ad000 C:\Windows\system32\USER32.dll
0x000007fefd890000 - 0x000007fefd8f3000 C:\Windows\system32\GDI32.dll
0x000007fefb350000 - 0x000007fefb389000 C:\Windows\system32\WINMM.dll
0x000007fefebd0000 - 0x000007fefec6c000 C:\Windows\system32\msvcrt.dll
0x000007fefd900000 - 0x000007fefdad8000 C:\Windows\system32\ole32.dll
0x000007fefeaf0000 - 0x000007fefebc3000 C:\Windows\system32\OLEAUT32.dll
0x000007fefb300000 - 0x000007fefb34f000 C:\Windows\system32\OLEACC.dll
0x000007fefea30000 - 0x000007fefea5d000 C:\Windows\system32\IMM32.DLL
0x000007fefed80000 - 0x000007fefee81000 C:\Windows\system32\MSCTF.dll
0x000007fefef30000 - 0x000007fefef3d000 C:\Windows\system32\LPK.DLL
0x000007fefef40000 - 0x000007fefefda000 C:\Windows\system32\USP10.dll
0x000000006d760000 - 0x000000006d76e000 C:\Program Files\Java\jre6\bin\verify.dll
0x000000006d3b0000 - 0x000000006d3d7000 C:\Program Files\Java\jre6\bin\java.dll
0x000000006d310000 - 0x000000006d31a000 C:\Program Files\Java\jre6\bin\hpi.dll
0x0000000077230000 - 0x0000000077239000 C:\Windows\system32\PSAPI.DLL
0x000000006d7b0000 - 0x000000006d7c2000 C:\Program Files\Java\jre6\bin\zip.dll
0x000000006d000000 - 0x000000006d1c1000 C:\Program Files\Java\jre6\bin\awt.dll
0x000007fef7920000 - 0x000007fef7978000 C:\Windows\system32\WINSPOOL.DRV
0x000007fefddd0000 - 0x000007fefea22000 C:\Windows\system32\SHELL32.dll
0x000007fefea70000 - 0x000007fefeae3000 C:\Windows\system32\SHLWAPI.dll
0x000007fefc380000 - 0x000007fefc579000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18000_none_152e7382f3bd50c6\comctl32.dll
0x000000006d600000 - 0x000000006d617000 C:\Program Files\Java\jre6\bin\net.dll
0x000007fefdd20000 - 0x000007fefdd64000 C:\Windows\system32\WS2_32.dll
0x000007fefea60000 - 0x000007fefea67000 C:\Windows\system32\NSI.dll
0x000007fefcb90000 - 0x000007fefcbdf000 C:\Windows\system32\mswsock.dll
0x000007fefcd00000 - 0x000007fefcd07000 C:\Windows\System32\wship6.dll
0x000007fefc2a0000 - 0x000007fefc2b3000 C:\Windows\system32\NLAapi.dll
0x000007fefce60000 - 0x000007fefce83000 C:\Windows\system32\IPHLPAPI.DLL
0x000007fefce10000 - 0x000007fefce55000 C:\Windows\system32\dhcpcsvc.DLL
0x000007fefd120000 - 0x000007fefd159000 C:\Windows\system32\DNSAPI.dll
0x000007fefd650000 - 0x000007fefd66c000 C:\Windows\system32\Secur32.dll
0x000007fefd540000 - 0x000007fefd54a000 C:\Windows\system32\WINNSI.DLL
0x000007fefcde0000 - 0x000007fefce0b000 C:\Windows\system32\dhcpcsvc6.DLL
0x000007fef8d40000 - 0x000007fef8d53000 C:\Windows\system32\napinsp.dll
0x000007fef86b0000 - 0x000007fef86c7000 C:\Windows\system32\pnrpnsp.dll
0x000007fef8d70000 - 0x000007fef8d7b000 C:\Windows\System32\winrnr.dll
0x000007fefdcc0000 - 0x000007fefdd15000 C:\Windows\system32\WLDAP32.dll
0x000007fefc7d0000 - 0x000007fefc7d7000 C:\Windows\System32\wshtcpip.dll
0x000007fef9600000 - 0x000007fef9608000 C:\Windows\system32\rasadhlp.dll
0x000007fefaf20000 - 0x000007fefaf31000 C:\Windows\system32\DWMAPI.DLL
0x000007fefc010000 - 0x000007fefc061000 C:\Windows\system32\uxtheme.dll
0x000000006d2a0000 - 0x000000006d30b000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x000007fef7300000 - 0x000007fef74df000 C:\Windows\system32\d3d9.dll
0x000007fefccd0000 - 0x000007fefccdb000 C:\Windows\system32\VERSION.dll
0x000007fef8140000 - 0x000007fef8147000 C:\Windows\system32\d3d8thk.dll
0x0000000180000000 - 0x00000001807cc000 C:\Windows\system32\nvd3dumx.dll
0x000000006d620000 - 0x000000006d62b000 C:\Program Files\Java\jre6\bin\nio.dll
0x00000000335f0000 - 0x00000000335f8000 C:\Program Files\Hewlett-Packard\HP MediaSmart\HPShared64.dll
0x000000006c280000 - 0x000000006c769000 C:\Windows\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\mfc90u.dll
0x000000006c1a0000 - 0x000000006c23d000 C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_99b61f5e8371c1d4\MSVCR90.dll
0x000007fefc7e0000 - 0x000007fefc7e7000 C:\Windows\system32\MSIMG32.dll
0x000000006dea0000 - 0x000000006dead000 C:\Windows\WinSxS\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.1_none_92995f253c01eddb\MFC90ENU.DLL
VM Arguments:
jvm_args: -Xmx500m
java_command: EGUI
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\hp\bin\Python
USERNAME=Justin
OS=Windows_NT
PROCESSOR_IDENTIFIER=AMD64 Family 16 Model 2 Stepping 3, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows Vista Build 6001 Service Pack 1
CPU:total 4 (4 cores per cpu, 1 threads per core) family 16 model 2 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext, sse4a
Memory: 4k page, physical 8386876k(6282784k free), swap 16829624k(14521540k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (14.0-b16) for windows-amd64 JRE (1.6.0_14-b08), built on May 21 2009 00:52:56 by "java_re" with MS VC++ 8.0
time: Tue Jun 16 03:16:00 2009
elapsed time: 92 seconds
If anyone has any idea why it does that please help me I WILL REALLY APRECIATE IT.
Sponsored Links
I believe the best thing you can do is contact the creators of moparscape. At any rate, based on the error messages, seems the failure of the program has something to do with your RAM.
Reply to le13enforce
Tom's Hardware > Forum > Games General > PC Gaming > Java problem
There are 889 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
