start up problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
hi all,
i reinstalled xp to partion a second drive and now when i start i get a
black page with:
windows xp home edition
and asks which i want to start with first go's to xp front page second
go's to a nother page saying <windows root> system32\hal.dll. not
installed or corrupt re-install but i run xp again but still get the
same message. is there something i can do to get rid of the second copy
to stop this happening.
regards
stuart sparks.
stuart sparks
G
Guest
Guest
Stuart, rt click MyComputer>select Properties>Advanced>Startup and
Recovery-Settings>Edit That will open the
Boot.ini file which will look something like the example below. Just
Highlight and delete where I have it marked.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(3)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(3)\WINDOWS="Microsoft Windows XP Home
/fastdetect
/fastdetect < Highlight this line and delete it.
C:\="Microsoft Windows"
"stuart sparks" <stuart.sparks.1n3bpp@pcbanter.net> wrote in message
news:stuart.sparks.1n3bpp@pcbanter.net...
> hi all,
> black page with:
> regards
> stuart sparks.
> stuart sparks
G
Guest
Guest
> hi all,
> black page with:
> regards
> stuart sparks.
Cannot Find \Windows\System32\hall.dll
http://www.kellys-korner-xp.com/xp_haldll_missing.htm
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com./athome/security/protect/default.aspx
http://defendingyourmachine.blogspot.com/
G
Guest
Guest
that's because you have 2 installations of XP 1 per partition.
it has recognised this and hence giving you the choice - even though in this
case they are really the same OS.
Were you trying to reinstall XP? and not intending to have two
installations? You should have chosen the partition that already had XP on
it, or chose to 'reinstall' or 'repair install'.,
> hi all,
> black page with:
> regards
> stuart sparks.
> stuart sparks
