Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I recently installed Windows XP (Home) on my computer (in addition to Windows
98SE).
When I first installed XP, it went straight to the desk-top on boot-up.
Then (for no apparent reason) a screen came up "To begin, click your username",
and I had to click on it to go to the desk-top.
Someone suggested I get Tweak-UI, and change the settings on "Logon" >
"Autologon", and check "Log on automatyically at system startup".
I did, and for one or two logons things go OK, but then it will revert back to
showing the "To begin, click your username" screen.
How can I make this selection permanent (or at least till I choose to turn it
off)?
Second: On Windows 98, there are a bunch of icons right next to the "Start"
button, which are sort-of "quich access buttons" to certain programs.
One of them is "Show Desktop".
At any time, I can select it, and the desktop will show again.
Is there a similar command or button in Windows XP?
Thanks!
John <><
A wise monkey is a monkey who doesn't monkey
with an other monkey's monkey.
(A very free paraphrase of Exodus 20:14).
Read the instructions at the top
61. Right hand side
Restore/Add Show Desktop to Quick Launch Bar
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:7c7b5193rmfo9o87nrdtri5cpl91r477l4@4ax.com,
John <nospam@nospam.ca> hunted and pecked:
> Windows 98SE).
> username", and I had to click on it to go to the desk-top.
> back to showing the "To begin, click your username" screen.
> turn it off)?
> "Start" button, which are sort-of "quich access buttons" to certain
> programs.
> Thanks!
> John <><
>You must've installed Microsoft .Net Framework or the update in Windows
>Update.
Perhaps - not knowingly or intentionally, though . . .
I notice in the Control Panel > Add or remove programs, Microsoft .NET
Framework1.1 is mentioned as removable.
Considering the fact I don't network, and don't intend to, what would be the
repercussions of removing thisprogram?
Would it solve my originally mentioned problem?
>PRB: Welcome to Windows Screen Appears When You Start Windows XP After You
>Install the .NET Framework 1.1
>http://support.microsoft.com/default.aspx?scid=kb;en-us;827072
>What is the ASP.NET Machine Account?
>http://www.mvps.org/marksxp/WindowsXP/aspdot.php
>Second: It's called Quick Launch.
>If Show Desktop Icon is missing from Quick Launch Toolbar...
Thanks for your help! I've got this OK now.
John <><
Don't uninstall it. Many newer progs need it to run. It actually is a new
programming system/style interface .NET
Tumppi
Reply to group
Most learned on nntp://news.mircosoft.com
Helsinki, Finland (remove _NOSPAM)
(translations from FI/SE not always accurate)
"John" <nospam@nospam.ca> kirjoitti viestissä
news:ssqb51hog8j964inrh61dpg2j0hfv79ipe@4ax.com...
> Additional question and a remark in-line
> On Thu, 7 Apr 2005 15:24:44 -0600, "Wesley Vogel"
<123WVogel955@comcast.net>
> >Update.
the
You
> John <><
John,
Depends if you have any software that depends on .Net Framework or not.
I do not. I also do not have .Net Framework installed.
..Net Framework doesn't necessarily have anything to do with networking.
[[What is the .NET Framework?
The .NET Framework is a development and execution environment that allows
different programming languages & libraries to work together seamlessly to
create Windows-based applications that are easier to build, manage, deploy,
and integrate with other networked systems. ]]
http://msdn.microsoft.com/netframe [...] fault.aspx --
Wes
In news:ssqb51hog8j964inrh61dpg2j0hfv79ipe@4ax.com,
>> Update.
> the repercussions of removing thisprogram?
>> You Install the .NET Framework 1.1
>> http://support.microsoft.com/defau [...] -us;827072 >>
>> http://www.mvps.org/marksxp/WindowsXP/aspdot.php >>
> John <><
>John,
Wes:
I have uninstalled .Net Framework.
As you already said it would, it did the trick.
Thanks for your help! I appreciate!
John <><
John,
Keep having fun. :-)
Wes
In news:4u1h51hrjfv4fma0246f3p9ie399q5ar0n@4ax.com,
> On Fri, 8 Apr 2005 07:09:40 -0600, "Wesley Vogel"
>> John,
> Wes:
> John <><
