Tom's Hardware > Forum > Systems > HP > HP Pavilion System Locked Pre-installation (SLP)
Forum Systems : HP - HP Pavilion System Locked Pre-installation (SLP)
Archived from groups: comp.sys.hp.hardware (More info?)
Hello,
I've fried the motherboard and cpu on my HP Pavilion 710
I'm getting a new m'board and cpu but I've discovered that HP machines use
the System Locked Pre-Installation 'feature' whereby in the HP Factory the
copy of Windows XP that is installed on the harddrive is given the bios
string of the HP machine it is installed on.
I had planned to remove the hard drive from my Pavilion and install it on
the new setup - as my machine will technically not be a HP anymore does this
mean that the system will not boot as xp will know it is not on the hp
machine it came with? This is a farce! I have paid for the copy of windows
xp that came with the Pavilion and my hard drive is stuffed full of paid for
software and data which I cannot afford to lose.
Is there anyway around this or am I incorrect in my understanding of how
this works?
Cheers,
TD.
Sponsored Links
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi TD,
OEM Windows is tied to the computer it came with. Unfortunately you
did not buy WinXP when you bought he computer. You paid for a license
to use it on that SPECIFIC computer.
Personally, I think that I should be able to use the license on any
one computer. That though only works if you buy the 'retail' version
which is not tied to any specific hardware.
Ciao . . . C.Joseph
That which a man buys too cheaply . . .
~ He esteems too lightly
toedipper wrote:
|Hello,
machines use
Factory the
it on
does this
windows
paid for
|this works?
|Cheers,
|TD.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (MingW32)
iD8DBQFBO77f6bFq6mlbLOwRAurRAJ4htJM7KpUsRlUGwugM9m2a3nvNnQCg0wje
Qvk8aW++pGZXI70E2B1NxKo=
=pykk
-----END PGP SIGNATURE-----
Reply to Anonymous
You might consider downloading one of the 'live' Linux CDs, use that to boot
you computer, and then burn a CD containing all the stuff you want to save.
I'm not sure which of the live CDs include cd burning sw, but if your data
is still on the HD this may be a way to recover it.
craigm
"toedipper" <mytemp.access@virgin.net> wrote in message
news:rC3_c.1286$V57.1096@newsfe5-win.ntli.net...
> Hello,
this
windows
for
> this works?
> Cheers,
> TD.
Reply to craigm
There are 1130 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
