Tom's Hardware > Forum > Games General > Console Gaming > PS3 Component Problem
Forum Games General : Console Gaming - PS3 Component Problem
Hello i recently came into a problem with my PS3, i plugged in all of the corressponding colors of the component cable into my tv and the when i turn on the PS3 no video shows up, so i was wondering what could be the problem.... could it be the cable or the console itself??
Sponsored Links
Was your PS3 used through a HDMI cable recently? If it's set up to run through HDMI it won't automatically switch back to component when no HDMI cable is available.
This happened to me. I had my PS3 running with the component cables. Then I hooked it up to another tv and switched to HDMI. When I went back to the component tv I couldn't get a picture. I solved this by going back to the HDMI tv and switching to component (using the XBM) from there. Then when I went back to the component tv it was fine. I hope this makes sense.
Reply to Micropat
Sounds like you used a different input at some point: Hold the power button down until you hear a second beep to restore the PS3 to default settings. (This also allows for any HDMI cables to be detected if you previously were using a component input). Make sure to set up your Video, Sound, and Blu-Ray settings again.
------------------------------ http://valid.canardpc.com/cache/banner/622598.png
Reply to gamerk316
There are 1075 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
  • 01:00 MasterSaji won the Uniformed badge
