Dream machine turns into nightmare
I put together the following system about 6 weeks ago:
Asus P4C800
P4C 2.8GHz
512 MB OCZ PC3500
Adaptec 2120S SCSI 320 RAID
2 73GB Seagate 15K RPM Cheetahs in RAID 0
1 200GB WD IDE
Pioneer 120S DVD
Sony DRU-500AX DVD-RW/R+-
ATI Radeon 9700Pro
Hercules GTXP
The P4C800 worked for 1 week. I got another one. That one died last week. I decided that was it for that mobo (you only have to kick me in the groin twice before I get the message) so I picked up an MSI Neo-LSR.
I did a clean install of everything and all seems well except that when I first turn it on I get an invalid boot disk error. I reboot and everything is fine. WTF?
The 200GB WD is only used for storage. There are no boot records on it. Also in the BIOS I have only the RAID array listed as a boot option. Any ideas? Everything seems stable otherwise.
Okay, brain. You don't like me, and I don't like you, but let's get through this thing and then I can continue killing you with beer. -- Homer Simpson.
14 answers Last reply
More about dream machine turns nightmare
  1. Many people have problems attempting to run their OS on RAID arrays. The boot sectors can become corrupted in the striping/mirroring process. Especially since Windows XP will only give you a 512KB cluster size during format (regardless of how you set it up in the RAID utility), as opposed to 64-512MB that is suggested for RAID. Third party software can help you work around this, assuming that it is the main problem. Try running the OS on a single drive for about a week. If it remains more stable, then RAID itself is probably the culprit. I had to resort to running a standard drive as my C, and the RAID 0 array as my D drive. I'm sure there are better options, but I haven't gotten enough feedback myself to see what.
    <A HREF="http://www.rebturtle.com" target="_new">rebturtle</A>
    <A HREF="http://www.rebturtle.com/turtletech.htm" target="_new">My System</A>
  2. I have a P4C800 Delux and was planing on installing a RAID array in the near future. I have been running a single C drive and the system is running quite well now. I hope Murphy wasn't listening. What utilities should I get before I set up the RAID array? I'm running XP Pro.
    I specifically bought this board with the intent to learn a little something about RAID arrays. Looks like I may need to learn a lot more before I rely on it for my primary system.
    ZZSpaceman
  3. Murphy ALWAYS listens :lol:
  4. It is not normal that 2 mobo's die after a week of good operation. If was you I would check the powersuply very good. A bad powersuply can also be the reason of a wrong boot. I have seen a lot of trouble beceause of bad powersuplies. People who almost build a total new system beceause the old one didn't work, and in the end find out that it was the powersuply
    <font color=red>duk-tape is like the force, it has a bright side and a dark side, and it keeps the universe together.</font color=red>
  5. yes the powersupply is a very important component not to go cheap on when you have this kind of system.....there is alot of +12V sucking components in this system and enough to overload an underpowering powersupply, which can damage components such as the motherboard!......
    Here is my recommendation for a top quality power supply for your system...it will run you around 100 bucks and its well worth it
    Enermax 465AX-VE (FMA)
    Here is also a good read on power supplies
    <A HREF="http://firingsquad.gamers.com/guides/power_supply/" target="_new">http://firingsquad.gamers.com/guides/power_supply/</A>
    <A HREF="http://dnadesignz.kicks-ass.net" target="_new"><b><font color=green>MY SYSTEM</b></font color=green></A>
  6. Invalid boot disk can be cuased by changing the BIOS or having the BIOS Virus Detection on.
    when you see smoke is that a good sign?
  7. Thanks for the suggestions all. Of course since I posted this it hasn't been doing it lately. I have an Enermax 550W PSU. I'm using MSI's Core Center software for monitoring voltages and they have been a bit on the low side. Here are some low readings:
    3.3V - 3.23
    5V - 4.89
    12V - 11.70
    I discovered a new problem. Once I set up Core Center on my PC it immediately gave me an alarm for a slow CPU fan. I still had my case open and to my surprise the fan wasn't spinning at all! I now use an adapter to plug it straight into a molex connector and all seems fine. Now my question is would an Asus P4C800 not POST if the CPU fan isn't spinning? When I had the P4C800 installed the fan was spinning whenever I looked inside. Could the wire on the fan be faulty and not be getting continuous power? Or is it just the header on the MSI motherboard? What's a good aftermarket HS/fan for a P4?
  8. Quote:
    I installed an <A HREF="http://www.thermalright.com/slk900.html" target="_new">SLK-900u</A> with a Vantec Thermaflow 92mm fan. I like it ...
    I also see others running either a <A HREF="http://www.zalman.co.kr/english/product/cnps7000cu.htm" target="_new">Zalman CNPS7000-Cu</A> or some Swiftech.
    I'd just try to find reviews and take a look at what others are running and figure out what you like from that.
    HTH.
    IC7-G 1.3| P4 2.8 800 | SLK900-U / 92mm Fan (AS3) | 2x512mb Corsair PC3500C2 | 2x120gb SG SATA RAID 0 | 2x120gb WD RAID 1 | CM ATC201B-SXT | 520W | Radeon 9800 Pro | Audigy2
  9. I haven't paid too much attention to HS/fans because the stock P4's are decent. I think the primary characteristic I'm interested in is the least noisy.
  10. Quote:
    well, i'd go read some reviews but definitely check out those two main ones above. I really like my 900.
    As for noisy, don't go with a Tornado 92mm ... it will blow your ears out!! Very loud! I tested it and man it spins and screams. But, it's hard for me to tell how noisy this sys is anyway as I have 5 other machines in my small office and it's not the quietest room especially if I have my extra A/C on!!
    -ot
  11. I found out that a low noise power suply is totaly useless if you have 5 7200rpm harddrives in your computer :-(
  12. Absolutely! With my fans on medium, the hard drives become the loudest part of the system!
  13. If you want a low noise cooling fan the best is the panasonic panaflo series fans..you can find these on newegg.com..they are axial fans and push alot of air with minimal noise...the thermalright slk-900u is the top of the pack when it comes to hsf cooling...
  14. the problems are NOT the fans. Is there someting to do about the HD noise. I have seen a noise reducer for 5400 rmp HD's but not for 7200 rmp hd's. Some of my HD's are already 42'C under good cooling conditions, and i dont want to risk a teperature above the 50'C.
Motherboards
